They're a nice deck with plenty of functionality but that slider bar control drives me nuts. For me personally I would run with something like a Pioneer DEH-P8650MP but it all comes down to personal opinion. Have a play with one and see if you like the deck.
Things to look for include the DAC, number or pre-outs, S/N and DSP abilities. >_<
cheers, thanks for that. problem bieng i already have the 9855R, i just havnt found a car to put it in yet :( having an RRP of $1099 and finding it for sale brand new at $750 i just bought it about a month ago, but now im wondering wether to keep it or sell it for $800 (still cheaper than RRP) and get a new deck
Some issues some guy posted on ns.com.. 9853r tho!! same thing in a way..
-the touch bar thingy is tricky for scrolling to the next menu screen
-there's no clock
-apparently the antenna goes up whenever the unit is on (even if you're listening to a cd). my antenna is unplugged though
-the cd text display doesn't show many letters at once.
-the cd text display scrolls too slowly. it also doesn't scroll the album title and track title at the same time. the album title just sits still while the song title scrolls and vice versa.
-i can make the 4 main buttons light up any colour i want, but the other buttons have to be red or green
-there's no clock
I have a 9855 installed in my car. I picked it up for 550 off of ebay....
anyhow.
I love it to bits, find it much more advanced then the 9857 (meant to be a more user friendly option)
the slide bar can be tricky at times but there is a skill to it, and the parametric equalizer is great... i much prefer it over the equavilent pioneer model, although it does have 5 volt preouts and the 9855's are 4.5V.
Here are the FACTS corrected...
-There is a clock on the 9855, with a date, and it also has greetings for christmas etc. :dry:
-The antenna does not go up whenever the unit is on... (i would check your wiring mate)
-The cd text in scroll mode doesn't show HEAPS of letters, but i find it enough to identify songs...
-The cd text display is a little slow, but i dont know why you would want everything to scroll at once... There are two lines and they display song title and artist quite well....
-All the small lights can only be red or green correct.. I dont know of many other models that even allow you to choose. It is a good feature...
The 9855R is also a revised model i believe, as the first ones had problems with buttons dieing and the eject mechanism.
I would keep it mate unless your looking for a serious upgrade. it is a nice deck ;)
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
