i have a Pair of Gt-t R34 seats in my car
Wanta Sell to bring S15 bak to stock look
Gt-t seats pair both with Rails
Clean no tears great seats great for bigger build person
Make me a offer need to sell to buy new seats
Offer made by nismo Gt waiting on me to get my act together
if he baks out Priced at $400
Edited by scottman
shipping is about $100 might drop them to $320 if buyer offers me money and pays up soon i wanta sell
if these fit an R33, i'll buy them for $320 plus postage to Melbourne
ok man i PM u
i think it will be $440 posted cause it might be up to $150 shipping i'm pretty dam sure they fit a R33
cause a31 r32 r33 r34 all same rails
S13 S14 S15 all same i think
ring import wreakers or something to make sure cause i'm not
Only R34 GTR are the same as R32 and R33
R34 GTT are on their own
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
