Tip for the day...don't buy at BP Toowong (cnr Jephson & Sherwood Rds)...their fuel is the dearest around. Regular unleaded hovers between 133.9 and 135.9 and with Ultimate roughly 10c per litre more expensive, I may as well live in Rocky with Cy :thumbsup:
I can drive to Graceville (5 mins away) and pay the above prices for Ultimate and the other good thing about the BP at Graceville is that its a 7/11 and therefore WILL accept the BP fuel voucher from Action supermarket.
The only other BP I have found that will accept the BP fuel vouchers is the BP on Fairfield Rd at Yerongpilly (sp?) or Yeronga (not quite sure of where the suburb changes).
  • Replies 45
I got the whole docket thing worked out too, and we dont have to spend anymore than we should on groceries:
1. Shop at Action and buy normal stuff, no meat or fresh produce, get 4c/ltr off.
2. Use 4c/ltr docket at BP, there is only 1 BP in rocky that has ultamite, and get tax invoice.
3. Shop at local foodworks and buy meat and fresh produce only, which is usually the cheapest anyway, and get another 10c/ltr to 15c/ltr off the fuel receipt.
Lucky everything is very close here in rocky, so instead of paying the usual ~150c/ltr for ultamite, I end up paying ~135c/ltr, which aint bad, too bad the Stagea is a tank and drinks faster than a russian on death row! Meh the price I pay for driving a slow volvo.............. :thumbsup:
for those skyline owners in caboolture/morayfield... the best prices are usually at the Shell servo along morayfield road... yesterday they had fuel (normal 92octane) for $1.21 where as the caltex up the road had it for $1.36... i lined up for fuel at the shell yesterday, paid $1.31 for optimax...
damn fuel prices... althought i get a pay increase in september just to accomodate for those prices :thumbsup: and there aint no way i am going to be selling my gt-r... when i get it that is
Tuesday is the best days in cab/morayfield for fuel... usually pretty cheap...
Edited by gtr_r32_reddy
That is my local!!! woot..It is just barely in Yeronga It usually has pretty decet prices too
Tip for the day...don't buy at BP Toowong (cnr Jephson & Sherwood Rds)...their fuel is the dearest around. Regular unleaded hovers between 133.9 and 135.9 and with Ultimate roughly 10c per litre more expensive, I may as well live in Rocky with Cy ;)
BP Cannon Hill cnr Creek & Wynnum Rds accepts them too.
Paid 138.9 for Ultimate at Toowong on Monday arvo - must've got lucky with end of long weekend
Only the ones with two heads :domokun: I tie a balloon with a smiley face on it to my shoulder to fit in :(
139.1c/ltr this morning
Weird thing:
136.9c/ltr in rocky last night, and it was 130c/ltr in Yeppoon last night as well....
After 9pm every day seems to be the right time to shop.
Im sure i could arrange express post for you Cy It could be there by next day arvo ? :whistling:
Edit: I just remembered where you lived
It will be there the next day the following week :P
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
