  • Replies 67
Posted Images
Wolverine: yeah,they use an afm to control mixtures. on the neos though,there's a map sensor that's there to monitor boost,and the ecu then triggers the cut at the level I mentioned earlier,as reported by my the peak hold on my digital boost gauge. if Sk can sucessfully dispute this,great,maybe I'll learn something.
Alex: if the cut is actually the AFM hitting 5v,how do you guys with larger turbos handle the problem? are you running Z32 AFMs? guys with far more power than my car makes have been running the std AFM for a long time and still have plenty of resolution left in their airflow maps.
I've felt an AFM 5v cut out before on an S14 I owned a while back,and it's way more savage than what the neo does at EXACTLY 1.0kg/cm3 of boost.
it's a limiter in the ecu. anyone who doubts this is welcome to meet me somewhere and experience it for themselves.
Justin...
It is not the AFM maxing out but its the AFM registering an AF that is too high for a specific rpm/load.
THis is based on the std tune which is given.
What a DFA/SAFC does is "bends" the AFM voltage to trick the ecu in thinking there is a lower air flow than there is (this is OK as the std mapping runs rich anyway). So there is a certain % gain you can have with an AFM bender. Basically, these electronic units are variable resistors with multiple load points
Justin...
A quick explanation on “boost cut” and R34’s / Stagea S2’s;
1 The ECU cuts NOTHING, fuel still flows and the ignition still fires, so calling it a “CUT” is 100% wrong.
2. The R34/S2 ECU is a bit smarter than the previous versions, but like them, it still has Rich and Retard mapping that it reverts to when it detects something amiss. For example if the throttle position and the rpm don’t agree with the AFM voltage the ECU hops into R&R mapping.
3. The ECU doesn’t care about boost. If you fit an SAFC/DFA (or equivalent) you don’t get R&R mapping. If the ECU cared about boost then fitting an AFM voltage bender wouldn’t work
4. Combining #2 and #3 above, you use an AFM voltage bender to realign the AFM voltage with the throttle and rpm. So the ECU thinks that all is well and doesn’t get into R&R mapping.
I hope that clears up the fallacy of boost cut and Skylines/Stageas.
:D cheers :dry:
fair enough. so.....what's the MAP sensor there for? purely for the optional gauges that aren't an option on the stagea?
while we're talking the whole panic mode thing in the ecu,I've seen that before as well,at about half as much boost as I currently run,as I had too much base advance dialled in at the CAS (thanks CRD...). if it detects pinging,it winds the boost and timing back,and goes rich,as you've described.
that isn't what happens at 1.0kg. it CUTS.
like I said,you're more than welcome to experience it for yourself,and then talk to me about it.
Peter at Advan refers to it as a boost cut,and was adamant about why it's there,and why they don't run a std turbo above it.
I may be a newbie to you guys,but I've been around cars (nissans and otherwise) for quite a while now,and actually know a thing or two. being that I'm also a qualified mechanic,I reckon there's a chance that I have at least half an idea about what I'm saying.
if I'm not sure of something,I'll say so.
if I say it's a cut,there's a VERY good chance that's what it is.
anyway,the offer is there mate,and I'd actually not mind your input.
I'll be putting my car on the rollers on sunday. if you want to meet up and have a chat about this,pm me,and i'll let you know where I'll be.
Justin...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
