Hi.
info:
Have a s13, with CA18DET - Now done a conversion to RB25DET.
After 3 months of waiting for my loom from Mckinney motorsports, it finally arrived. But!!
The lower rb25det harness does not hook up with my fuse/relay box.
The RB25DET lower harness connector with 6 pins does not fit in the 8 pin jack that is at my fuse box. (I'm guessing its for starter signal, and its also for the gearbox sensors?) Also the other plugs from the lower RB25DET harness wont plug into the plugs at my relay/fuse box!
Also, the little loom that goes to the knock sensors, there is a plug left over... Were do that go?? (Not one of the two plugs for the knock sensors)
Please help me out here.. As its the only thing left before my car runs.
https://www.sau.com.au/forums/topic/122308-heelp-with-s13-rb25det-wiring/
  • 1 month later...
Hi there.
i got it up and running. Started first time when i got the correct lower wiring loom.
But. 3 weeks later the bolt that holds the cam belt pully broke!! That resulted in 24 bend valves. :D
So now ive bought yet another engine. hehe.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
