I have 18x9.5 or 18x10 inch rims (im not sure of there exact width, i measured it with a tape, and it depends wether i measure to the lip or the entire rim)
I currentley have 265/35 tyres. What is the max width i could go on a 9.5inch rim and a 10inch rim?
Cheers.
You measure the width of the rim from the inner lips of the rim.
cos the outter lip can vary in width and shape it is never acurate to measure form the outter lips, always form the inner of the lips on a rim.
https://www.sau.com.au/forums/topic/122404-tyre-width/#findComment-2260831
by the books. a 10" rim is normally good for about a 300/12" tyre, i think thats about the maximum recommended size. Ill let you know if we fit our new 290mm dunlop slicks onto our 9.5" rims. Could be a little awkward, but should be ok.
Edited by r33_racer
https://www.sau.com.au/forums/topic/122404-tyre-width/#findComment-2261255
The maximum width for a rim size is actually dependent on the tyre and its construction. A good manufacturer will post the minimum and maximum rim widths on their web site.
Falken seems to recommend no smaller than a 245 for their 9.5" rim, and no wider than a 285, regardless of the tyre.
https://www.sau.com.au/forums/topic/122404-tyre-width/#findComment-2261304
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
