Hey guys my GTR came from japan with a blitz ID Power Meter.This is all good so far but the way it was wired into the car was not to my taste (at least they didnt drill any holes).ok now while i had an alarm fitted i told them to disconnect the ID meter so i can later wire it the way i wanted to, that time has come :D
ok now it has a red wire and an extra red wire spliced into it, one black wire and a white wire which must of been short so it was extended with an orange wire (must of ran out of white)
now im guessing the:
RED- power (but why is it spliced and now there are 2 red wires)???
BLACK- Earth ???
WHITE/ORANGE- I have no idea ???
Does anyone know what/where the WHITE/ORANGE wire goes.
Where should i get power from?
Anyone have a diagram for this that they can post.
I have attached a pic i took of the whole thing (sorry about quality of pic its from a camera phone.post-7189-1150683639.jpg
Thankyou
Thraso
https://www.sau.com.au/forums/topic/122818-blitz-id-power-meter-installation/
Thanks heaps michael :P
i guess that pic is the back of the standard GTR comp and shows where to connect the white wire ?
I have one red wire but its spliced to make 2? should i get rid of one? (i have attached another pic highlighted)
Where should i get power from ?
Thanks
Thraso :D
Thanks
Thraso :D
- yeah that correct, thats the stock gtr ecu pin layout.. basicly fine the wirer in the loom which goes to that pinout and connect it to that
-hmm not sure why the red wire is spliced into 2 maybe chop that off. i jsut connected mine to the power wired that goes to my deck
Yeah thats what i was thinking about the red wire just had to be sure.:)Is there a wire there already in that slot for the ecu?
If so do i connect them together into the ecu?
once again thanks alot Michael.
Thraso >_<
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
