hey guys,
i have this problem with my left suspension it sound like something is lose and going to fall apart i am hearing all these different stories of what it can be? i was thinking it might be worn bushes or is it something much bigger
Perhaps you should have a look around and see if anything is outta place, if you have no idea what your looking at then perhaps you should take it to a suspension mob and see if they can see anything outta place. The chances of someone going yeh this is your problem, just from a simple "my left suspension sounds like its going to fall apart" statement are pretty bloudy slim. You need to provide more accurate detail on what is it exactly your hearing, feeling, noticing while driving, be it accelerating, braking, reversing, cornering and what have you. Then maybe someone can throw a more accurate answer your way.
Apologies if my reply seemed rude, was not the intention :D
lol sorry
its got bilstein shocks and springs its pritty hard suspention, the car seams to handle the same and when taking corners it doesnt make any noise when reversing or anything like that the only time it makes noise is if i go over a hole on the road or if the raod is abit bumpy, i dont know how to decribe the sound it just sounds like something is lose i spoke to my mechanic today he recons the strut might be gone.
Funny that!, I am having the same shit problem... Ya hit a bump and its like a knocking or rattling noise and the rear end feels like its gonna slide out even though youre in a straight line. I had the standard shocker replaced and the noise is slowly coming back again as if the lowered spring is mashing the shocker. Let me know if ya get a solution!!! Cheers.
