Hi guys,
I need to get a small piece of pre-resined carbon sheeting. It must be real carbon. dont want any coloured weave, just the regular black/grey weave is fine. Could possibly buy some weave then just do the layers and resin myself but i'd prefer pre-fab. It's just to fill a hole in the centre console and will then use it to mount some switches etc.
Any help pointing me in the right direction would be much appreciated.
Richard
  • Replies 46
Posted Images
We've got some... bought off a supplier in Brookvale. If you want I'll get you the supplier details, otherwise tell me what size you want and I'll see if I can find some offcuts.
exactly like that! only just black/grey CF instead of kevlar weave, and also half that size (replacing the 3 gauge cluster).
but i'll take kevlar weave in a pinch if someone had some lying around (hint paul!). :D
i left some at Croydon's...ill ring em and see if its still there...ok
i'm excited. i'm going to use that space to mount the defi link controller and the dirtgarage D1 edition awd switch. and maybe relocate the ultra speed meter there too.
If that falls through, try going to a boat building place, there are a few around that make the sydney to hobart boats... We used to get their 'offcuts' to make our body work for a little SAE car. Cant remember who we used last year but its worth a shot, not something that comes to mind at first though is it!!
Do you have an oven? remember the pre-preg stuff needs baking!!
thank mate, yep i do have an oven. but i think a flat sheet that has already been laid and coated wont need any more prep work. just drill my holes and bolt it in.
Ahh yep, sorry i didnt realise it was just going to be a flat sheet that you want.
Good luck with it, post pics for general interest when you are done?
I am about to go to CRD myself, been speaking with a bloke called Jim, i need a few things done to my car. Hopefully within the next few days, things keep getting put on hold for me. I just want my car fixed, running nicely and back on the road
thanks for the kind offer Aaron. I'm going to chase up a lead tomorrow morning, but if they haven't got what i need i may take you up on that. we have some resin left and i guess i could just buy some regular fibreglass weave to make it 1 layer CF, 2 layer fibre...
I will let you know :P
BB
i may have sum left over if you want it, its only thin tho (1mm) carbon weave , guess can glue it to 2mm perspex to make it thicker, so yeh let me know if you need it.
aaron
Hi Aaron, if BB doesn't need it, I will take it. I need to replace a gauge panel and a POD heat shield cover so 1mm would be perfect. What are the dimensions?
:P cheers :D
Biatch,
There's a place in the same complex as UAS that does custom carbon fibre work... They were working on this 100% carbon fibre body race car the last time I dropped by.
The guy is very eccentric, but he does amazing work. He made custom sized sheets for this exact application for me a few years ago... Very cheap too. From memory I got him to do 3 layers of carbon (ended up being about 3mm thick and BLOODY STRONG), and a gloss top coat in double-din size, and it cost me about $30-40.
Can't remember the shop number, but I think the guy's name was Alan. John will remember the guy if you ask him.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
