I'm soon to replace the stock front speakers in the line with some nice splits and I was going to replace the speaker cable too. However, I've had a quick look at the cable routing and it looks like it's going to be impossible to pull new cable through the rubber tube which joins the door to the chassis. Has anyone done this before? I'm hoping I don't have to pull the door off! ;)
BTW.. if I were going to run the splits off the headunit I probably wouldn't bother changing the cable but I plan to run them off an amp :)
Any handy hints are much appreaciated.
Thanks
Easy done bud, you are right when you say you can't go through the rubber tube but if you look about 10-15mm above it you will see a hole that you can pass the cable through without any hassles. If I get the time tomorrow I will post a pic for you :D
Thanks for the hints so far guys :laugh:
The biggest problem about just pulling it through is that the tube has a big kink in it. But I reckon that plan along with 2GU UP's plan would work. If I pull the rubber out of the door I should hopefully be able to straighten it out and pull cable through easier.
heslo if you can post up a pic that would be great. Your idea sounds like a good backup plan :D
I tried to do this... my rubber tube goes to a big wire-harness.
I unplugged the wire harness (on the a-pillar) and found a bolt holding the other half flush with the pillar. Undid the bolt, then lost the whole thing in the pillar hollow.
Pulled ECU and stuff out, but I can't see any way of getting in there. (got it back with my long finger, and lots of poking around in the hole...hehe)
Ended up putting it all back together and giving up on the idea... where would you run the speaker cable through? There are no other factory holes in my A-pillar.
hmm... well we have the same car RANDY so I wouldn't be surprised if I end up with the same trouble. Though heslo said he got it through another hole and he's got the same car too! We shall see where this wire runs when he posts up his pic.
I did this about a week ago... found I could not go through the existing rubber tube....
if you have a look about 10 - 15 mm infront (towards the front of the car) there is another little rubber gromet (think thats what they are called... i used that to pass the wire through...
(my bad if heslo and I are speaking about the same hole...)
parish, that's the same one I'm talking about! Easy to find, just have to look, even feel around with your fingers. As soon as you locate it, it will be easy for you to feed the wires through, you just need to know where to start
Not sure what the wire is for but I have fee 10g speaker cable through the factory loom and plug.
Very much a mission, but you basically unbolt plug in where loom goes through chassis. You can reach up under the dash to access that end of theplug, it simply clips into the chassis, then as you bolt the plug together from the door side, it holds nice and firm.
So after unbolting, you relocate a few pins (if using large cable, say 10-12g), so you can drill out plastic in bothends of the plugs. You then have a hole to feed your new wire. Then the rest is as usual.
Be careful not to pinch wire when bolting plug back up.
I have done this in both my skylines, very much a pain the ass, but worth it for the factory look.
I may have posted more detailed procedure on these forums previously, try a search if you want more info.
Hope this helps anyone wanting to do this.
I found the best way was to get a drill, pop in some new holes where required, custome make your own rubbers between car and door and run what ever you like through it.
My car is a s2 r33 and there was more than enough room for 2 x 8 guage power cable ( yes used as speaker wire) and a few other wires for "other devices" mounted in the doors.
If you do this, just remember to seal the holes around the rubber with some sealant, you dont want water getting into your ECU or anything..
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
