I have the Following parts for sale that i have no need for as i no longer have a GTR and these parts are wat i have in my garage and need to go
KIT TO SUIT RB26 - Full twin turbo KIT (aftermarket) , 2x BB GT2840 turbos and Manifolds to suit , Including Wastegate (55mm) , Dump pipes , screamer pipe , Braided lines (water and oil) , and intercooler pipes . the turbo kit has done around 7,000 k's of street use and has ran a 10.6 down the strip . All is in perfect condition , manifolds were made custom with the rear turbo high mounted and the front turbo low mounted .
VERY CHAEP at this price
$6,000 neg
- 1 Set of Wiesco forged pistons , 87.0 mm , to suit RB26 in good used condition , like new .
$ 700
- 1 set of Wiesco forged pistons , 88.0 mm , to suit RB26 also in good condition with low k's like new .
$ 700
- 1 set of stock RB26 rods that have been Shot peined and have ARP rod BOLTS
$ 500
- 1 set of HKS cams , 290 duration with 11.0 lift , also done low K's ,
$ offers
1- GTR r33 gear box in perfect condition , gear box only ...
$ 1800
1- SX Fuel regulator , in the box never used
$ 350
1 - Bosch Fuel Regulator with braided line
$ 160
2 - Defi gauges in BF style (1 boost , 1 oil temp ) gauges only
$ 200 each
1 - R32 GTR seat (drivers side) in good condition
$ 350
1 - RB-26 single throttle body conversion kit,85mm throttle body is
new,manifold,spacers (to replace original thr/bodies) can use std 300zx
accelerator cable!! bolts in perfect.
$1500
1 - set of larger stock throttle bodies , have been made larger to 48.50mm , never used , new condition .
1-set (3pcs)
$ 750
1- ARC Hood Panel to suit r32 brand new in packet .
$ 130
1- set of RB26 coils (6pcs)
$ 400
1 - set of RB26 Injectors (6pcs)
$ 300
1 - set of HKS camgears to suit RB26 used .
$ offers
1 - Full set of stock Valves from RB26 , Valves only .
$ offers
1 - 3" stainless muffler
$ 100
1- Recaro Race seat (fix back) 2.5 kg carbon kevlar seat .
$ 1000
1- Custom Fuel surge tank
$ 100
2 - stock RB26 heads in near new condition , bear heads only . (no cams/valves)
$ 900 for one (head only) , 1100 for the other head (head only) .
(will also sell heads with valves/buckets/retainers for extra)
All parts are LOCATED on the gold coast
Would perfer pick up , will post at buyers expense .
Please contact mark on the following details for more information .
thanks
# 0410 657 805
e-mail - [email protected]
Have posted most of the important pics up , if other pics are needed please let me know .
thanks
Edited by 2jz-180
the price for the HKS cam Gears are $250 for the pair ... thanks guys ... and please don't make stupid offers as i have recieved in the last few days .. thanks
I've always been interested, how hard is it to fit an r32 gtr seat into an s13?
it's very easy to fit a GTR seat into an S-13 as that wat i have and thats wat i had the seat in , 3 of the 4 standard bolt holes line up just have to drill a new hole for the outside back mounting point :wub:
will the wiseco pistons fit an rb25......
Not sure .... Not an engine builder but i'm sure they could be made to fit as long as your block is preped for that size piston
Pic of the GTR Gearbox please, interested.
Don't have pics of GTR box , but don't really see how that will help you ? as all GTR Gear box's look the same on the outside , it's whats inside that counts :D
Hey, what size are the fittings on the SX regulator?
I'm assuming its rising rate?
yeah it is rising rate , and not sure on size of fittings , but thats not a hard thing to work out when fitting to the car , might have to buy a few $2 brass fittings at the worst :P
Edited by 2jz-180
1:1 rising rate?
how much do you want for postage for the SX regulator to Melbourne (3079)?
you got any mounting brackets or anything?
yes it has the brackets in the box , never used ... 1:1 i think , 370 should cover post ? not sure how much post is to melb ? just $350 plus post which will be somewhere under $20 i'm guessing
interested in the gtr injectors. what condition are they in?
good condition as stated in post .... :) for best responce call :)
  • 3 weeks later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
