Ive extended the group buy and have aranged the pricing for minimum of 5 or 10 buyers (see first post).
Be sure to let me know your insert colours and coating colours(if required).
  • Replies 45
paul just one thing, my R33's brake line comes out of the place in a 90 degree angle, not from the bottom, is that all right for your line??
if so,ill take one set with blue insert with clear plastic cover please.
also, do you still have those halogen bulbs on sale?? what do they look like? cheers!!
Anyone else? We need one more buyer to make up the 5.
Hello paul,
Master cylinder GTR33 Braided Line.
Count me in.Smoke with clear cover
Tekin
:D
ok...we have 6 buyers so far.
Do you all want to wait untill we get 4 more buyers or do you want them asap?
As per the first post you will get them a little cheaper with 10 buyers.
I can wait too, but having said that guys,we really need to set a date.
Say End of this Month September?
I think this is the way to go.......
What do you all think?
Cheers
Tekin :P
no probs fellas.
Ive changed the finish date:
Finish date - 28/09/06
Payment due - 01/10/06
If we get the numbers before this time then we'll finish it early.
Sound good? :)
Sorry guys,
I have to pull out of this...car is going in next week to get Nismo braided lines fitted
and lots of other stuff so i won't need them..Cheers :)
Keen for one for a R32 gtst Blue inserts, Clear coating but have a few questions first.
Is there a reason why they use a juction box and extra line standard? Maybe to damper the pressure? will this line affect the pressure needed or stroke required at the clutch pedal or will it cause pressures outside the cylinders capabilities? If anyone can answer this that would be good.
Is the picture an example of the clear coated ones?
Is there any proof sent that these are ADR approved?
Steve from Maltech has kindly supplied this info on the clutch lines:
"The only reason that l can see for the extra line and junction block is to give the clutch pedal a softer feel. Nissan is the only manufacturer that l have ever seen this set up on.
The master to slave clutch hose may make the clutch pedal slightly firmer to push, but we just fitted this type of hose to a GTR that had an extra heavy duty clutch fitted and you could hardly notice a difference in the pressure required to push the pedal.
The master to slave clutch hose will not affect the operation of the slave cylinder in a negative way.
Response from customers is nothing but positive, first point is that the hose was easy to fit, clutch bleed up straight away, and they now have a much more positive feeling clutch pedal, you can actually feel the point that the clutch is engaging at, and this point is exactly the same every time.
Clutch hoses are not required to meet any ADR standard, but having said that the master to slave clutch hose we produce does comply to ADR as it uses exactly the same hose, inserts and fitting type as the brake hoses.
This hose is also tested to 3500psi
Regards
Steve
Maltech"
I hope this helps :)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
