  • 4 years later...
Bump.
Interested in this too, new exhaust tomorrow, was originally going for 2.5", but am looking at 3" after some reading. No point going to 3" with the standard dump and front pipes if they're only 2.5"...
stock r33 is 2.5" just measured my stagea one, its ok to go from 2.5" to 3" cause after a while your exhaust gasses will cool down and expand so technically going from 2.5-3" is perfect. also a 3" down pipe costs bugger all these days.
also from memory, the top half of your dump pipe is 3" and the bottom piece is 2.5"
Searched and bumped a dozen threads looking for this answer! I'm having problems with the car dropping boost after 4000-5000rpm. Given it's only running ~5psi and dropping to ~3.5-4, there has to be a restriction somewhere, and given that a GTST runs 9psi after 4500rpm, I doubted it'd be the dump/front pipes.
So 2.5" should be perfect for my needs, and a good step-up over the N/A cat, center pipe and center muffler.
2.5" mandrel is good, but a proper 3" system is always best and will see you get better figures. i went from original to JJR 3"- 3" stainless cat 175cell- HKS hi power silent 3", made noticable difference, but currently running split front pipe, 3" no cat and a straight pipe with HKS endpot. makes even bigger difference then with a proper system, sounds nicer too, but not a very wise choice! EPA, cops, etc
if yours is blocked, try swapping out the cat, if its not that, you could have a blocked Muffler, so to recap, only go to 2.5" if you dont plan on upgrading anything! go to 3" if you want more headroom
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
