Well now that I don't have access to Victorian tradeplates, I can't slap it on the ae86 to drive it to track days n shit, so I need to tow the fcuker around... I can either molest the R32 or the A31, and being a family car the ceffy's gonna get the chop. Plus sometime down the track the widebody kit's goin on the R32 (eventually... lol) so I don't really want to have to chop it up to accomodate a towbar.
As the 86's a light rusty POS, it'd be a max of 1200kg (allowing 1000kg for the car and wheels and 200kg for the trailer). Can a RWD cef handle towing something like this?
Does anyone have a towbar on their cef? if so can you post some pics of the bar and where it mounts on the chassis? Also places where you can get em done, prefabbed kits if you know of any and costs if possible.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/
from http://www.towbarfactory.co.nz
NISSAN CEFIRO
1990 to 1994 SEDAN
Vehicle Chassis No: A31
Towbar Serial No: 175
TB Code: NIA31
Tow Weight (Non-Braked): 500
Tow Weight (Braked): 1500
might be an avenue.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2295069
NISSAN CEFIRO
1990 to 1994 SEDAN
TB Code: NIA31
might be an avenue.
your a ledgend shan. i've also been looking at the possibilities of this as ill need to tow a light weight sailing boat in the near future with my ceffy. Only thing i'm questioning is the rb20 in the ceffy, don't know how it will go with the low torque, will probably be spooling up non stop. :)
Let me know if u have any luck finding somewhere in australia that make them. I remember hearing something about the s13 tow bar possibly fitting, but again not sure on that.
Edited by skypy12
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2302026
yeah, I'm a bit concerned about the ceffy being RWD and towing a car. Might have to end up using the R32 as its AWD... both of them are RB20's though... plan is to run it at extremely low boost when towing.
Its easy enough to get a prefabbed on from NZ so I might not bother getting a custom one made up in oz. Its a bonus that the tow ball is removable, so I don't have to worry about it looking fugly.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2303072
RWD is fine for towing. just make sure the weight balance of the trailer is right and it will be all sweet. eg don't put too much weight at the back of the trailer so it starts lifting the rear wheels of the car up if you know what i mean.
So getting parts in from NZ is generally a feasible option financially?
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2303727
Trailer design and overall weight will play a major role. Especially when using a small (for towing) capacity engine. I think I read somewhere its ideal to have 80kg of weight pushing down on the ball. So dummy loading the vehicle, spares etc and marking where car sits for the best balance may be an idea.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2303843
i was thinking of using a towing dolly instead of a trailer more recently, that way i don't have to worry about the weight balance etc, and also its cheaper at $400 for a brand new unit compared to a trailer. Only issue might be front bar having to be removed each time i tow the 86, and also i'll have to go a little slower than with a trailer. I'll also have to worry about the 86's wheels turning too i guess.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2316047
apparently the car being towed must be rego'd or something... pfft... sif. might end up with a front wheel a frame or something, apparently if a pair of wheels are off the ground then the car dosen't need rego.
https://www.sau.com.au/forums/topic/124274-towbar-for-cef/#findComment-2319383
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
