$250 plus shipping champ
let me know
unless you like to swap for some parts you might need
cheers anf
$280 + postage, as i still have to remove the tyres
If you are interested , please PM me with the delivery post code so that i can get a price on postage.
https://www.sau.com.au/forums/topic/124717-sold/#findComment-2324045
Hi there buddy, any chance you could post another (clearer/closer) pic of the ANZs?
My GF bulldozed a brick fence with her MA70 supra and needs 2 new ANZ rims that look very very similar to those.
Any idea of offsets?
Oh BTW, nice looking tyres...i can understand why you arent selling them with the wheels!
Cheers,
Troy
https://www.sau.com.au/forums/topic/124717-sold/#findComment-2335507
Sorry PPL, just got my car back from the mechanic's, after 8 weeks, and spent the whole weekend upgrading the interior :D.
Will get some scales from work and weigh the rims this week. Will then notify all interested parties.
(Bowlsclubboy) Troy: Just letting you know that i will not seperate the rims :D, but will be happy to take some more pics if you are interested in buying all 4. No idea of offset, but they fit inside the 33 gaurds nicely. Would it state the offset anywhere on the rim itself?
Yep, tyres are going on replacement rims :D, will be hitting the track in November at Wakefield and Easterncreek :D.
https://www.sau.com.au/forums/topic/124717-sold/#findComment-2335792
heh its ok mate, the 8" rims could be put to good use on my cressy drift car :D
Another pic/s of the ANZ rims would be great, as long as the others hold air when a tyre is jammed on em, thats all that matters heh
Cheers
https://www.sau.com.au/forums/topic/124717-sold/#findComment-2337964
Last week i barely logged on as i was feverishly working on my car, after work, getting it ready for yesterday's SAU VIC event, Drift 4 Dummies.
Admittantly i have done sweet F all with regards to the rim pics and weights. Will get on top of it this week.
https://www.sau.com.au/forums/topic/124717-sold/#findComment-2349804
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
