Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
Subscribe- I have to check my oil cooler kit first (got it last friday but havent opened it up)
More so interested in the thermostat. What size Barbed fittings does it have?
Can it be supplied with a 70-75 deg spring? Or can it be adjusted to open a little earlier?
You have a kit? I didnt think i had sent you one?
The fitting size i will get back to you very shortly on :angry:
As for the temperature, they only come in 82degrees
  • Replies 125
Posted Images
1 more question :)
how do these fit on an R33? and what are the dimensions like on the smaller core.? would it be a neater fit?
Here is a guide to installation
http://www.skylinesaustralia.com/forums/in...=79130&st=0
But another method that is popular is slotting it infront of the radiator
The dimensions for the smaller core are.....
11” x 4-1/2” x 1-1/2” and uses female 1/2 NPT fittings
As for neatness of fitment, really it depends where you put it but in confined areas then id say yes it would be a neater fit :O
hello steve have you fitted one to your? if so can i see some pics please seems a little big.
Thanks brad
Brad, i havnt fitted one to my car yet (although i will) because the motor spun a bearing about a week before i organised this group buy :D
When its all back together i will be using the black core fitted where the stock airbox resonator is :(
Hey mate,
interested in the Thermostat only for $100 delivered..
Does it come with the fitting showed in the pic?
Pm me with payment details..
Hey mate,
No worries, PM sent :)
dumb question, the oil filter? is it the same z145a or will it b using a commodore one like just jap kits?
sounds a bit titearseish..but dun really wanna keep forking out $15 for a oil filter every month and a half (5000kms)
Edited by J_R32
Hi Steve
Is this still going ,im after the thermostat set up as I already have the remote filter and cooler , If so would you please pm me the details
Cheers Peter
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
