Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
  • Replies 125
Posted Images
im interested in single filter and thermostat and if u can supply i need a sandwich plate for two gauges,whats availability and price please. i allready have a cooler.are the hoses in kit screw on connections to cooler or hose clamps? i can wait for thermostat but need rough time about when would get incase to long.(want engine back in and running b4 xmas)
thanks.
sorry, how thick?
Approx 3-4mm, i dont have one here though so i cant measure up for you sorry
thanks.
Hi
Single filter and thermostat shouldnt be any problems, ETA on delivery is about 14 days currently, so yeah Xmas should be fine
Send me a PM by the end of the week if you're keen and ill sort it out for you, other than that this GB will be closed >_<
pm sent! :/
Replied ;)
No way I JUST LOGGED ON today to get your pm. Your group bay doesn't officially close til tommorow.
Please send me a B&M cooler, twin filter relocation kit, and thermostat.
How do I pay, please, please, please!
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
