Few things been sitting in the garage for far too long...
All off 95 R33 GTS-T except for the pod setup which is as stated. Don't like the price...make me an offer.
Prices for pickup from Perth metro. Delivery at buyers expense.
CAI Box: $160
Purchased off Maxx from these forums some time ago. Never fitted, does not work with my VERY direct intercooler piping. If you use the stock piping location through the engine bay it should work perfectly. Great build quality. More info available in the original post...
http://www.skylinesaustralia.com/forums/in...=radaitor+panel
Series 2 Rear Spoiler in White: $50 SOLD
Sticker as pictured 'Nissan Motorsport International'. Brake light works perfectly.
Floor Mats: $50 SOLD
Full set of 5. Drivers side dirty and worn through where clutch foot rests.
Sub & Amp Box: $150
Missing one sub and amp. All hand made with stainless steel front cover and carpet around the rest.
VERY well built, fully sealed 3 cubic feet box. Amp and Sub can be put back in if the incentive is
good enough! You can see from the original image what it looks like with an MTX amp and both subs.
Can get dimensions if interested.
Lancer POD and extras: $80 SOLD
K&N Pod with custom made AFM adapter and custom 2.5 to 3" stainless piping with stock hose connector.
Includes CAI pipe. Direct fit for 1.8ltr models. I think the engine is the 4G93. Your little brother will love it :thumbsup:
Contact via PM or mobile 043 800 1990
Further Pics on request.
post-8519-1152002184.jpgpost-8519-1152002202.jpgpost-8519-1152002212.jpgpost-8519-1152002222.jpgpost-8519-1152002230.jpgpost-8519-1152002247.jpg
https://www.sau.com.au/forums/topic/124865-r33-gts-t-parts-for-sale/
  • 3 weeks later...
Ill take the sub box if its for 15's ^_^
sorry mate. forgot to mention that. the box was originally made for 12's. wouldn't imagine 15's would fit even if cut out a bit, but can check if you like?
top offer on the CAI box so far is $130... will do it for $150.
will do the sub box for $80 without the sub in it...which means that the sub is also up for sale. top quality MTX 6000 series. $70.
  • 3 weeks later...
pod off the lancer now also gone. still got the CAI, sub and sub box.
also have Nismo LM GT2's in 17" with tyres becoming available in the next week. price around $1300. pm if interested or wait for seperate post with them next week.
  • 2 years later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
