Normally its the Valve stem seals that are stuffed when you start the car and it blows blue smoke.
If the seal is stuffed around the valve then overnight or over a period of time oil leaks down on top of the Piston creating a nice pool of oil for the morning when you start it up hence the puff of blue smoke.
However the oil leak is not enough to notice once that initial oil has burnt, and you wont notice any blue smoke when you drive.....until you leave it turned off for a long enough period and the oil builds up again.
https://www.sau.com.au/forums/topic/125337-blue-smoke/#findComment-2314730
If it is your valve stem seals this would be the cheapest fix of all the Oil burning related engine problems >_<
The valve stem seals themselves are only a few dollars, but its still fairly time consuming removing and replacing them all.
Best Guess $400.....?
https://www.sau.com.au/forums/topic/125337-blue-smoke/#findComment-2314746
Interesting you say that and it makes sense.
I *think* my RB20 is reasonably healthy given it's still running and nothings changed while I've been giving it a hard time. >_< But I do remember not using it for about a month or so a while back and when I went to start it and this huge puff of blue smoke came out on start up. But since then I have yet to see a mist of blue smoke, I'll assume it's because I drive it at more regular intervals now.
https://www.sau.com.au/forums/topic/125337-blue-smoke/#findComment-2314751
hey pull your spark plugs out have a look and see if there is any oil on top of the piston (screwdriver and a rag), or get yaself a compression tester from super cheap there like 30 bucks (or get your mech to do it if your unsure) and check the compression.
https://www.sau.com.au/forums/topic/125337-blue-smoke/#findComment-2314754
do a compression test. This is the easiest way of determining what's wrong.
If it's lower than 120psi or if it's very low in one cylinder, put about 10ml of oil in each cylinder and do the test again.
-if the compression is good (all above 120psi and no more than 15psi variation between cylinders) then i'd say it's the turbo seals
-if the compression rises on the second test it's definantly rings or pistons
-if the compression doesn't rise on the second test, then it's valve related (or could also be the head gasket), i'd say stem seals most likely.
https://www.sau.com.au/forums/topic/125337-blue-smoke/#findComment-2315118
Guys i started the car this morning, so its been sitting there the same amount of time last night if not longer. And there wasnt a trace of blue smoke on start up, but just a bit of blackish smoke when i got my g/f to rev it up a bit
https://www.sau.com.au/forums/topic/125337-blue-smoke/#findComment-2315202
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
