Guys i know this topic had been covered before. I know cos i read it before buy i couldnt find the post.
Anyway my car got the factory tapedeck. And the radio doesnt work. Lower Fm frquencies. How do i fix this problem. There was an adapter or something which you can purchase. Where can i get it? What is it called?
Thanks again guys.
https://www.sau.com.au/forums/topic/125465-radios-in-the-stagew/
Thanks again guys.
You need a band expander more information in the car stereo FAQ section
http://www.skylinesaustralia.com/forums/in...showtopic=94069
Thanks again guys.
any stereo shop, just ask em for a convertor for a nissan import radio and they will have them. im unsure of the exact name off the top of my head sorry.
i dont think i'd bother as the radio is rather crap and cheaper cd units are gonna be 100 times better anyway :)
just my 2 cents worth
Brad
Yeah I agree with that too brad only time a band expander would be useful is if you had a good aftermarket headunit from japan
in your case stasis I think the 260 has a single din headunit as a result of the gauges so any aussie head unit will fit in and single din head units can be found pretty cheap these days and you can then get mp3 and all the other goodies
Yeah its basically a FM converter.... I had one off an old Nissan Tape deck from my skyline so I put it into my Stagea on the original tape deck.... I can pick up most stations now but I get alot of background noise and distortion too..... If you can afford it you are better off getting a new deck... decent one will set you back a couple of hundred....
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
