hey,
after a heavy duty clutch. dont want to spend more than $500.
heard good things about exceddy daiken clutches.
but dont know where to get one.
some thing with a full faced centre on it. dont want brass button. still want it to be able to handle around 230rwkw at the end.
i am using the rb30et flywheel probly. so do i get the clutch to suit the flywheel or the clutch to suit the rb25det gearbox? will it still be doable with the rb30et flywheel. after all its an rb series motor and gearbox. i heard they are interchangeable.
any advice welcome.
https://www.sau.com.au/forums/topic/12568-heavy-duty-clutch/
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
