A couple of semi-unrelated questions which I have attempted to wrap into one thread for the sake of verbosity.
My car has arrived with the door trims removed and put loose inside the car. The company doing my compliance seems to think think this is a big deal..
So I asked the nice man, why it matters since they have to take the door trims off anyway to weld in the side intrusion bars.
Only he then says: "we dont need to do that on skylines older than 1992".
Can anyone confirm this information? am I paranoid or is he jerking me aboot?
I havent even taken possession of this thing, but my experience living vicariously through mates motors has led me to beleive that everyone who does work on jap performance cars is a bit dodgy - and this seems to contradict advice I have previously received.
https://www.sau.com.au/forums/topic/12587-compliance-bit-of-an-emergency/
second of all, does anyone know anything about the ADR / road rego requirements for having a rear brake light installed on the vehicle spoiler.
I would be keen to NOT put back on the original factory spoiler, but have been advised that I will not get it over the pits without it.
I do have a rear wiper, and am wondering whether it would be feasible to remove this and install a back-shelf brake light in it's place.
edit: typo
yeah as jeff said they already have side intrusion bars.
plus, you do need a rear high mount brake light, either on the spoiler or the rear window. We glued one to the rear of my window to pass compliance and the pits, then it came off :P
Shaun
so basically, the majority of the work which would be carried out in a 'service' should already be included in the cost of compliance.
does anyone know of a government/ADR/dotars list of the work which must be carried out during compliance? I have tried to track one down, but Im having trouble getting anything more than:
"this is the work which MAY need to be performed, including.."
The workshop that complianced mine did show me, Phils Mechanical. All fluids should be changed, new air filter element, spark plugs if necesary, light bulbs in some cases, seat belts, child restraints in the rear, new tyres on all corners, etc etc etc... There are many many points that need to be addressed. Plus the workshop should make sure the car is mechanically sound and test drive the vehicle. Mine had a rooted drivetrain when it came in, it vibrated badly at 60-100km's, they first thought it was the wheels and did an alignment, didnt fix it so they pulled the drivetrain out and all 3 unijoints needed to be machined and replaced, ended up costing me another $360 ($120/joint inc labour). But the car drives smoothly up to 200km/hr... dont think I've been much beyond that and dont want to either :(
yeah, that's right cam.
I was quoted $x for compliance, with tyres being additional, and now Im being asked to pay for additional works which Im not sure should actually be additionals at all. Hence I just wanted to know what it is that should have been included in "compliance".
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
