I know this is a skyline appreciation forum but i have always been open minded about cars. If the XR6t had been around when i bought my GTS25t i would have had a much more difficult time deciding on buying my skyline.
In the following link they say that with a couple of tweaks and some extra boost you get 252rwkw out of the XR6t. How tuff is that. Also they say that 300rwkw would be a "doddle", that will really put the wind up someone driving a HSV with 300 flywheel kw.....
http://www.fordforums.com/showthread.php?t...25&pagenumber=1
I think it is impressive that a local manufacturer has finally come up with a MODERN performance car. None of this single cam push rod junk but a really serious peice of gear. Mind you dont get me started on how the intercooler is plumbed because that really was a MAJOR COMPROMISE.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/
bolting on a turbo doesn't instantly makes it a well refine sportcar as a skyline. but it does help the falcon street cred though. if u get a chance hurl one into a sweeper at the same rate as u would do in a skyline and see how much room there is left in ur undies. It's still a family car in the end.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-230877
Hungry 6 have you tried driving one????
It is more of a family car than a race car (skyline being a race car of course) as such it will weigh more.
I personally hate the way the intercooler/ inlet manifold/ turbo is piped because it is a compromise. BUT you cant argue with a family car that pulls 240kW running 6psi which is heavily detuned. Oh by the way can your car seat 4 people as comfortably as a XR6t???
I took one for a run and i was surprised at how the suspension combined with the traction control made the car stick under serious accelaration through some cornering. The sales person did get a bit edgy at times but i assured him that i was looking at upgrading from the GTS25t to a family car with some go (cough cough like hell i was).
They didnt JUST bolt on a turbo if you check the specs they also dropped the static compression ratio and did a lot of heat shielding among other things.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-230969
My mate works for the company that makes Ford's transmissions, and agrees the manual is at an end for torque handling, they have been leaning on it for years and keep asking to do what it was never designed to do, with this in mind the 5 spod doesnt do that bad a job.
He has worked primarily on the auto, and with him having driven my 32 GTST many times when im pissed and egging him on, he has a good idea what my car can do.
For the record the guy isnt full of BS, and claims despite the weight of the car, and saloon heritage, the development mules that he R & D flog my GTSt in accelaration, have great brakes, and handle great. He says with the handling you just have to be mindful the it is a production car with a pretty hefty kerb weight, so no brakes/heavy acceleration mid corner/ebtry to corner etc, be smooth and it can do the job. Hell he has driven the thing on great ocean road.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-231153
I've heard from a few sources that the XR6t has a boost limit of 7psi.
Once it hit's 7psi the ECU starts to pull back timing and then starts the boost cut - just like some R33 gts-t's hit at 12psi.
If this is true, it'd be a pain in the butt to go to a full ECU change on such a modern car for a few extra psi :D
They are nice cars though. Boss at work has a blue one... Nice......
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-231353
There was a good article in the last HPI comparing the XR6 Turbo to the Supra. They said "The closest thing to a Japanese car to come out of Australia. We can't praise the XR6T any more than that".
I think the guy doing the review was a little biased as he owns a Supra, but hey, what can you do?
The writer goes on about how the 2JZ-GTE is the greatest and most proven engine of all time, whereas the 240T still has to prove it's self. "The few players in the aftermarket who have tested the 240T engine have come away confused and frustrated with an uncooperative managment system, and intercooler/exhaust systems that are far from optimum".
Apparently the LPG spec rods are a must for a serious build-up.
They also said that the Ford doesn't like to be revved!
All in all though, I think Ford is onto a good thing. However, if I was looking for a sporty family car, I'd still by a WRX!
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-232077
OK
Firstly it is a 4ltr. Motors with large swept capacity dont need to rev much because the have bulk torque early on in the rev range where as my RB25DET needs to be revved to get any go out of it.
For a sporty family car i would think it is ideal because you get a large turbo six with auto. You can be as lazy as you want to be and you can seat 4 passengers with large arses comfortably.
https://www.sau.com.au/forums/topic/12619-ford-xr6t/#findComment-232092
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
