hi all wondering if anyone has had this problem and can help me out or heard of this.
when the car is driven at 90km/h or above a light comes on under the dash(above the foot pedals).this comes and go's about 2-5 second intervals. i only had it imported just over a month it stock bar cat back bov and clutch it's a r33 gtst s2. any help would be muchly appreciated. :D
https://www.sau.com.au/forums/topic/126531-can-anyone-help/
thanks for the feed back had a look and can't see anythink unusual.
will pull dash etc off and go for a run tonight. will let you know how it went.
did this tonight was the shock sensor light.nothing a bit of tape wont fix
:D
Edited by mr moo
https://www.sau.com.au/forums/topic/126531-can-anyone-help/#findComment-2337854
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
