Hey Guys,
Had my line for about 6-8 months now. Got it from Japan stock as a rock (only cat back kakimoto and coilovers). I've put a pod and heat shield since then.
It hasn't skipped a bit so far after 3 track days and plenty of spirited driving around town so I'm going to begin my power up project within the next couple of months. My aim is around 200-220 KW
Shopping List
Front Mount Intercooler
Hi-Flow Cat
Boost Controller @ 12PSi
Volt Stabiliser
Bosch Fuel Pump
Clutch (Exedy H/D Organic kit)
Apexi SAFC II and tune
I'm hoping this well get me to the mark but please let me know if you think I've missed anything out or have out something that’s not necessary in.
Do I also need a fuel cut defender? or with the SAFC bypass that.....
Thanx in advance for your help.
https://www.sau.com.au/forums/topic/126624-when-do-i-need-a-fueld-cut-defender/
R33 doesn't have a factory fuel cut, SAFC will by pass the max airflow protection (R&R)
better still = skip the SAFC and go for the power FC, as those mods wont get you the 220rwkw ... you would need a turbo upgrade
a safc won't avoid r&r, ask satanic. a safc can bring it on earlier if your car is running lean. a turbosmart fuel cut defender will get rid of it, but if you then use a safc you will just bring it back. the turbosmart fuelcut defender just moves it by telling the ecu it is getting less air then it is (leans it out). but then if you use a safc to richen it back up you just cancel it out (just depends on if your car is running rich or lean). but you are better off going a full ecu if you are aiming at that sort of power.
Edited by mad082
Would love to get a PFC but my budget wont allow for it. I've only got about 2K to burn.
From the above comments i come to this conclusion. Get a SAFC and tune it so it doesn't run as lean as a regular tune for a SAFC? OR Scrap the SAFC and just get a fuel cut defender? OR Don't bother and take the factory ECU to it's limits and spend the cash on a slit dump/front pipe?
Thanks for your help guys...
Sam
first thing would be to get the plit dump/front pipe. no matter what other mods you do, this is a must. and if the cat is stock then change that too. then stick it on the dyno and see what it gets, and how rich/lean it is running. if it is running rich then get a safc. this will boost your power, save you fuel, and you won't have any worries with r&r. you could also use a fuel cut defender to lean it out, but it isn't quite as precise. the turbosmart is the only 1 have seen that you can use it to lean out. all the others just clamp the voltage and won't let it read above that voltage.
Shopping List
Hi-Flow Cat
Volt Stabiliser
Bosch Fuel Pump
All for $2K, this will be tricky with a power target of 200 rwkw
FMIC and kit $500, check the Group Buy and Trader section, all of them will support 200 rwkw.
Hi Flow cat, Magic 4” $210 on the Group Buy
Boost controller $22, check out the thread
Volt stabiliser, waste of oxygen
Forget the Bosch fuel pump, your budget won’t allow it. Wire the standard fuel pump back to the battery using a relay. That will up the voltage from around 11.2 volts to 13.8 volts. Plenty enough for 200 rwkw. Cost $20 or so if you DIY.
Clutch $450, if you do the work yourself. If you can’t DIY, then forget it, live with the standard one until it dies.
Power FC $960m, plus tune $300.
500 + 210 + 22 + 20 + 960 + 300 = $2,012
There you go. If you find the injectors won't stretch, they should but just in case, get a Nismo adjustable fuel pressure regulator ($150 from Negun).
Now start saving because the ceramic turbine won’t last at 200 rwkw if you are doing track days. Plus at 200 rwkw you will most likely need an oil cooler. Then there is brakes pads, brake fluid, tyres, suspension etc etc.
:( cheers :P
:P cheers ;)
Thanks for the help SK. Helpfull as always. After reading your post about "Which fuel pump to buy? last night I had also decided to crank up the standard pump to 13.8V. Saves $250.00. WooHoo!!!
Your list above is pretty spot on to what I have figured out late last night after reading the answers to this thread but I am worried about the clutch.....I think it will let go very soon.
Is the SAFC really that useless? I'm still stuck between two things.
Tuned SAFC and new clutch OR Power FC and tune (with standard clutch that could be on its last legs)
Perhaps I should aim for 180 - 190KW.... :angry:
i know a guy that had a safc then upgraded to a pfc. no top end power increase, but down low it pulled a bit better. but if you kept it in the mid or high revs it went the same.
More info please...Standard turbo? What boost was he running? What KW? Did he have any R&R issues? If not...why not?
Cheers,
The SAFC forces compromises on you when you are tuning. You want to lean out the A/F ratios more but you can’t because the ignition timing gets more advanced and the pre-ignition gets dangerous. Most people choose safety and run it rich.
Some guys try for the highest max power, so they retard the CAS, then lean it out. This gives more top end power where the A/F ratios and ignition timing are at their best. But the retarded ignition timing (via the CAS) kills the mid range where it is too retarded. You can’t advance it with the SAFC because the A/F ratios are already as lean as you want to go.
This retarded ignition timing also kills the throttle response and delays the boost build. The car might make the target power, but it is dull and unresponsive to drive with poor (comparative) average power. This means it gets blown away by cars with lower max power but the higher average.
I can (and have on the Stagea) tune the SAFC for the highest average power, I really don’t care about the max power. Where the power advantage (max or average) lies in the Power FC (compared to the SAFC) is purely a matter of how each one of them (particularly the SAFC) is tuned.
When does the compromise become too much to bear? Tough question, it varies with each car. My rule of thumb is, standard injectors and standard turbo are OK with an SAFC. As soon as you upgrade either one, it’s PFC time (if it’s a manual of course).
:angry: cheers :P
:angry: cheers :P
My next question being.......
Is a SAFC really worth it for the money. Will there be a majour difference between an "Average Power" tuned SAFC and a Stock ECU? (if I have a slit dump/front, cat and 10-12PSi boost)
Cheers,
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
