SOLD!!!!SOLD!!!!SOLD!!!!SOLD!!!! http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...E%3AIT&rd=1
:PBJ:
for sale i have this instument cluster taken from a r33 gtr vspec
comes with the three dash gauges also trimmed in carbon fibre
it has 29650km showing on it.
it is nismo eddition with the carbon fibre trim
pics below
$650.
email me cause i dont visit the forums very often.
[email protected]
Edited by 4LY-SYK
