Hey guys got some 32 GTR spares I need to get rid off....
Rear bumber bar with reverse lights- $150 SOLD
Side view mirors. gun metal grey - $50(each) SOLD
Starter motor - $150
Rear drive shafts - $100 (each)
Boot interior trim-$70 SOLD
Door trim - $150 each
0416 255 683
Edited by GTR090
https://www.sau.com.au/forums/topic/126769-32-gtr-spares/
Also got other random bits:
left door rubber
black piece dat fits under/in front of the windscreen
brackets that border around the windows(driver and passenger)
Windscreen wipers
Roof lining inside
https://www.sau.com.au/forums/topic/126769-32-gtr-spares/#findComment-2352076
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
