Hi , i heard that these japanese tuner has built a 800hp silvia S15 , a 650hp FD3S and a fast Evo but i cant find any pictures or informations about these workshop , the old net adress has removed , so i need help ...
can everyone post a few pics of them ?! please no videos , i know them :devil:
hope you can help me ... nice day ... bye
greetz . german JDM-Fan No.1 "CyberEvo"
https://www.sau.com.au/forums/topic/126842-garage-stillway/
Hi Peter :(
I couldn't find the Stillway site either... but I have some pics of the Stillway Evo 7 in the 'Photo Diary' thread in this forum. I might have some other pics on my PC, I'll upload them tonight (AU time) if I find any more.
https://www.sau.com.au/forums/topic/126842-garage-stillway/#findComment-2343089
they tuned my car, with impressive results. They have a good repuation, and rightfully so. However, they run a very simple operation, and that doesn't include a website (their old site was pretty much just a 'under construction' sign for as long as it was up).
if you want parts, check yahoo auctions - as they sell a lot of parts on there.
Edited by DaiOni
https://www.sau.com.au/forums/topic/126842-garage-stillway/#findComment-2354694
No shit someone been watchin too mahy DVD's!
You being a smart arse or serious?
Hi-octanes are the only DVD's I've watched as my friend has them. "IF" you were serious, they do a tour of japan and stillway wins because they just rock up and ask to film some hot cars and they tell them that they can TAKE the 900HP S15 or film the 600Hp RX7. Goes on to show the RX7 at what can only be described as warp speed on a back street then they go to a track day like rezz's photos with stillways track weapon RX7.
Signal, Kansai and veilside also feature. Signal take a 2.8L R34 GTR on the high way for a 300Km/h run
https://www.sau.com.au/forums/topic/126842-garage-stillway/#findComment-2381076
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
