Long story short -
1. car spluttering / not running smoothly when cruising in 4th gear @ 2800rpm (after 20 mins of driving / car warm) plus leaky injectors were getting really bad.
2. next day melted a coil.
3. changed all the injectors & replaced the coil - all good again.
4. took it for a drive today - same problem after the car is warm ... revs fine and goes hard still anytime but when im cruisin the car jumps back and fourth a little and runs all crappy.
ok ... so its not the injectors, could be one of the other coils but i just wanted to know if the airflow meters would be affected by heat ? ive only just put on a set of hks airpods and ive noticed all the piping and the outside of the airpods were really hot after i come home, just wanna know if this could be the problem or perhaps an 02 sensor ? but yea the car runs perfect untill its warmed up ... then it just wont cruise nicely :P
Thanks
Max
https://www.sau.com.au/forums/topic/126931-r32-gtr-hesitates-while-cruising/
  • Replies 45
Posted Images
ive got the same problem
i doubt it would be o2 sensors because if they were faulty, ie, not doing their job, then they wouldnt be leaning out the mixture on cruise. thus keeping the mixture richer and smoother.
i think the jerkiness i get with my gtr is due to dirty injectors having a terrible spray pattern at lower fuel pressures (ie cruising) from running a few tanks of petrol bloody low. however, you said youve changed the injectors
to be an AFM problem, you would feel the 'cutting in' and 'out' on all loads.
i reckon its still a fuel delivery problem. hows your fuel filter? changed it recently? these old gtrs have quite a bit of gunk sitting in the bottom of the tank by now.
the reason the car runs fine when its cold is that the mixture is enrichened by the ecu which compensates for the low fuel delivery when the car is warm
Edited by SLIPPERY
Well i just purchased the injectors 2nd hang which were sitting for a little while, not sure how long... and put them straight in, ill just have to get them taken out and cleaned ... weird thing is that it done the same thing with the previous injectors which were leaking fuel internaly really bad, this is what i thought the problem was ...
I might check out the fuel filter tomorrow ??
Perhaps another coil might be on its way out ??
Ill just have to get it checked out on a dyno or something ... :)
u should always get 2nd hand injectors cleaned before putting them in. FWIW, my injectors dont leak at all and i get the jerkiness so its not related to a leak, rather the squirter being a little clogged.
injectors can be cleaned for $20 each with a print out of before and after flow rate, plus a spray pattern pic.
i changed my fuel filter last week and its a 'tiny' bit better.
Long story short -
ok ... so its not the injectors, could be one of the other coils but i just wanted to know if the airflow meters would be affected by heat ? ive only just put on a set of hks airpods and ive noticed all the piping and the outside of the airpods were really hot after i come home, just wanna know if this could be the problem or perhaps an 02 sensor ? but yea the car runs perfect untill its warmed up ... then it just wont cruise nicely :)
Thanks
Max
Mate, I had similar problems, would only notice it when car is hot or being driven for a while. No doubt leaking injectors etc would contribute in your case.
Had my car checked out with a fault code finder and air flow meters were both on their way out...not completely f#%ed yet but was told would eventually die. Both of them!!!....reading different voltages above and sometimes below the norm.
Had both replace..expensive exercise and now car is running fine...no more jumpimg back and forth and lossing power.
As for the heat towards the AFM, I was told the crank case ventilation with hot engine oil mixing with air being redirected back through the air inlet causes this contamination in the air inlet and sometimes or over time the oil/heat can affect the AFMS. Recommeded an oil catch can setup to eliminate this contamination.
Oh yes, my 02 sensors weren't spot on either but was told this should not affect the driving of the car to the extend of not responding to the throttle when this happens and I would loss fuel injector signals. AFM stuffing up, telling the car that no air is coming in so fuel supply stops momentarily...car runs crap, jerks back and fourth for a few seconds, sometimes longer and then picks up again. I could actually see no fuel signal on the multi display screen when this happens.
Anyway, just something I've experienced and was told by my mechanic....that's my 2cents.
Good Luck
Naa thats awesome, ill just have to get my hands on a multimeter and have a play with the AFM's ... :domokun:
theres heaps of things for me to check / replace / fix hehe :)
:happy:
Thanks for all the replies
Good Luck
When an engine is running rich, it will run ok untill it warms up, then with the extra heat, will cause the engine to run super rich. I had a similar problem with my RB20. Piece of shit to drive, spluttering, cutting out. Turns out it had a small crack in the intercooler, wich with the afm's was causing it to run rich, and also at times, max the standard afm because of the amount of air it was thinking it was reading. Its worth a look and do a leak check..
un plug them lol :)
02 sen
It gets rather frustrating when people refuse to listen to good advise doesn't it!!!
Un plug the sensors and take the thing for a drive. Why do you think its running rich??
O2 sensor feedback perhaps??
Unplug the sensors it will take them out of the equasion and my money is on the thing running fine just as T04GTR has suggested.
Yea yea so anyway whats the deal ?? drive the car for 20 mins till it starts playin up and then unplug the o2 sensor ? or do it before?? is it hard to get too ? or will i have to take it out beforehand and take it for a drive ???
yeah. i rekon just replace everything and spend hours chasing your tale till you magicly fix it :(
do it in the garage before you start the car. you dont have to wait for 20 mins before you do it.
we all wanna know how it goes! :P
you dont need to take them out...just unplug their electrical plugs and go for a drive
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
