Yes well it isn't too bad. the person who hit my car while it was parked in Preston took off... leaving a 10cm inflextion on my rear bumper just under the right stoveplates.
The bumper has also come off on the right hand side by about a cm (probably the mounting has come loose from the impact or sumfin.)
The paint's cracked in the area and the plastic has sorta gone in in a shape which sorta looks like either the corner of a car or a bull bar or sumfin round as hit it in just one spot. The paint's chipping off, but the plastic dosen't look like it's cracks or fractured... jus inflexed by about a cm.
Dammit...
**** them dirty motha ****er
ARGH...
https://www.sau.com.au/forums/topic/12732-argh-hate-ppl-who-hit-ur-car-n-run/
shit man
sorry to hear about yer car monkey
at least they didn't loosen yer wheel nuts so later on yer wheel falls off while yer driving
did you have a pager alarm?
cos my friend's parked car was hit in the parking lot but his pager alarm went off and went running into the carpark and found the culprit, a 4wd.
this is why i hate mutha ****ing 4WD vehicles!
it happend to mine last week... luckily it wasnt as bad... they probably had more respect for it as its a GTST :D:D
but yeah pissed me off... back left has a nice big white scuff mark.
meh, jus had a closer look at it... the rear bumper isn't too bad, should sand out and with another coat should look the business...
but the real damage is to the bracket underneath... in one way i'm lucky the impact was right on the bracket, preventing the bumper from breaking. But the bracket is dented out of place (causing the bumper to come out a bit). I jus have to take it off and i guess flex the bracket back into place and it should be all good.
Does anyone know how to take the rear bumper off, and if the bracket that holds the bumper is part of the chassis, or if it comes off? Since Sam has a full black R32 GTS with a proper bumper I might grab a bracket off it or sumfin like that might be cheaper than gettint he bracket unbent.
I also found a yellow mark on the bumper... so looks like i either got hit by a taxi or a yellow car.
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
