Circuit Question, Fuses. (on Immobiliser Press, Indicators Flash Problem)
I have an aftermarket immobiliser on my car. When you press the button the doors lock & the engine is immobilised. To let you know this has happened all indicators flash once for locking, twice when unlocking.
Now when I press the button, only the drivers side indicators flash when locking / unlocking. So only 3 out of 6 flash. (driver side, front / side /rear)
All indicators used to flash perfect, but since some recent electrical mod / changes, all indicators are not flashing when the immobiliser button is pressed. (but yes all left / right side indicator do work when using the indicator stalk)
Below is a history of recent events to help troubleshoot at which point my problem starts occurring.
1. front passenger side indicator stops working, fuse is still fine, & all indicators (except for passenger side front) flash when pressing immobiliser button.
2. Go to an auto electrician to get a no load flash unit installed (to fix up my indicator speed due to 5 watt globes at front). Installed & indicator speed back to normal.
3. At same time get auto electrician to look at the front passenger side indicator which is still not working. Accidentally (from a jiggle of a wire I guess) the front passenger side indicator is now working again.
4. On the drive home, turning left, the indicator fuse blows & I loose all indicators. I guess it was front a driving vibration / jiggle again. (make it home safely)
*from here below I think at some point the new problem has occurred 'immobiliser press, driver side indicators only flash*
5. Buy fuse, replace the blown. Test indicators, instantly blows the new fuse.
6. Disconnect the front passenger side indicator, install new fuse. All indicators work except the disconnected front passenger side.
7. Today, check positive & negative lines to front passenger side indicator, rewire & cover with electrical tape. Install new fuse. All indicators flashing fine. But, when on immobiliser press, still only the driver side is flashing.
Also, I had to replace the hazard fuse, this was blow when the indicator fuse was blow. Is it possible another fuse has been blow?
Thanks for the long read & help :pirate:
Cheers, :(
Edited by geno8r
all new alarms have fuses for the indicator outputs, its to stop people shorting out the indicators like they do in gone in 60 seconds. so track down where your alarm is and it should have 2 fuses outside the unit.
i hope that makes sence
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
