As I’m buying myself a new car it looks like my Black manual 1989 R32 Gts-t Skyline must be sold.
Exterior
16” Watanabe Rims (Matt Black)
Bridgestone Firehawk tyres (only done 500km’s)
GTR Aluminum Bonnet
GTR Front Bar
GTR Grille
GTR Rear wing
Very straight body with no major accident damage
Tinted windows (darkest legal)Hybrid Copy FMIC
Full 3” Exhaust from turbo back
Dual Air horns
Tein HA adjustable suspenstion
Interior
Central Locking with alarm and Immobilizer
Seats in excellent condition with no marks or cigarette burns
HKS Boost Pressure, Exhaust Temp and Engine Temp gauges mounted in second DIN
Short Shifter
Hybrid Electronic Boost controller with high, low and over boost function (over boost is an extra 10% boost)
Engine
Upgraded Turbo (unsure what type but bigger than stock)
Rebic Fuel Computer with 2 extra injectors installed in the manifold
Remapped Ecu with speed cut removed
Front Strut Bar
Clutch has been upgraded, unsure of type but still grips very well and is strong
K & N pod filter
Sound
JVC removable face head unit that plays MP3/WMA’s
Clarion Component Splits in the front
Clarion 2 ways in the rear
2 x 12” Clarion Subs in the boot in a box (lots of space left in boot for luggage)
4 x 150w AVA Amp running the sub in bridged mode
Genearal Info
Car has just been serviced by Ice performance with the spark plugs and coil packs replaced.
I imported this car 2 years ago with 96,000 k’s on the clock; it now has 114,700 k’s. When I first got it I had the water pump and timing belt replaced as well as a new set of spark plugs (all done at ice). I have changed the oil and filter 4 times since I have owned it as well as the fuel filter being replaced.
Car drives well and recently did 196 rwks at 13psi. This was before the FMIC and EBC were installed.
I am asking 13K ONO.
Im in Melbourne, Southland area.
PM me or contact me (Jason) on 0409425887. Test drives available though if you are under 25 bring the cash or a bank cheque cos my insurance won’t cover ya.
Edited by linxus40
https://www.sau.com.au/forums/topic/127663-r32-gts-t-manual-black-for-sale/
noone want to buy a skyline? as it says ONO so make a reasonable offer.
i will also be including in the sale a nardi steering wheel in good condition that came with the car from japan, as well as the origonal shifter if you dont like the short shifter. i will also be including a stock air box so if you get defected for pod and fmic you can easly switch.
comeon make an offer. this car must be sold in 2 months if not sooner.
im willing to take out all the sound gear and drop the price by 400$
Edited by linxus40
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
