ok quick replies to questions today.
N1GTR. no the hose clamp will not be included in the packet a i am not gonna be postin them out, but the hose clamp it self should be bout 40cents at any hardware store or automotive shop and will be of size 12mm to 18mm as this is the size i used.(i "found" mine at work though hehehe)
SATANIC. the differences would only be in the thread size of your sump and as it states in the listings of engines on page 3 of the thread that most nissans are the same, a for the number tag it would be to identify you as the payer when the deposit is made, for example say they allow you to only put a string of numbers next to the deposit receipt number, some banks allow letters and numbers so that the payee can tell who it was that deposited the cash, somethin like this
deposit of $41 from satanic(real name) at blah blah bank on this date receipt number 6549613 with number tag 55689.
you then pm me with the details of the transaction/amount/receipt number and the number tag you put with it so i can identify you as the payer when i check the balances etc.
hope this makes it a bit clearer for ya but if not lemme know k
Edited by oxford1327
  • Replies 107
Posted Images
Hi Guys,
Just thought I'd check on this group buy and answer a few questions.
Thanks to Oxford for setting this up. I'm sure you guys will enjoy the valve.
A lot of questions are answered here http://www.fumoto.com.au/info.htm
Some of these questions have been answered, but I'll confirm the answers.
Yes I'm in on the group buy... can you find out if the nipple is removable?
There are two versions, non-nippled and nippled. The nipple is cast into it so, no, it's not removable.
Interested, but id like to know how hard the spring that holds the arm is So there is not a chance of it swinging open by itself
It's double-action, so you have to push it "up" then across through 90 degrees to have the ball valve completely open. It is still quite stiff. No way it would open due to vibration or hard jolt.
Will these fit an RB26, I remember reading somewhere that the magnetic ones you get don't fit the 26's sump, are these the same or are there different parts for each?
Unless the sump drain is recessed or there is a cross member/ sway bar in the way, there will be no problem
fitting the valve. Take a look at the pics and you will get an idea of how it mounts. These are not magnetic in any way.
All late model (1990 on) accepts F-103 (12mm-1.25). Pre 1990 - F102 (PF-3/8). Please check your sump plug if unsure (yes, it will be a pain, but you only have to do it once).
Will also fit RB25.
For honda s2000
Please note, Honda S2000 takes an F-106 and requires an ADP-106 (adaptor to allow the valve to clear the sump). This will add significantly to how much the valve sticks out, please be aware of this. I estimate 40-50mm in total.
does the lever have to be held open?? or does it lock into place??
Locks open so you can leave it to drain.
Can you find out what postage costs are - I'm in Perth...
Standard delivery charge to anywhere in Australia for any quantity. Included in your price.
one question. since its a ball valve and its underneath. exposed to dirst, water ETC. Will the ball valve works in the long run? if this matter is clarified i want one as well. Will it fit the RB26 engine ? Let me know.
If you get crap in it, hose it down, it won't mind. Stainless steel ball. If it leaks, I'll replace it...even in 10 years. Keep your receipt.
another quick question. Will the quick realease valve be sticcking out abut 1/2" to 1"? If one has tje car low will it be risking of hitting a bump with the valve and rip the whole thing off? Let me know
In total, it should only be sticking out 10mm more than your sump plug. As well, it will be on an angle so the actual distance from the ground is not excessive.
oxford are you able to put up a list of motors that this fits please?
http://www.fumoto.com.au/sizes.htm
Can it come with this? (Hose clamp)
Personally, I don't think you will need it (unless you go offroad in the Skyline), but for your own piece of mind, you can add a hose clamp, or use a small (1-2mm thick) cable tie. I can include some cable ties in your group buy (Oxford - please remind me).
Any other questions, please don't hesitate to ask.
Cheers,
Jack
EDIT: Had too many quotes.
Edited by Fumoto
Yes i read the whole thread and by the look of the chart on page 3 they will fit SR20
But just want to make sure, Will these fit a SR20?
If so you got another.
Yes, they fit SR20. Same F-103
Oh, in case everyone didn't read my reply to Oxford on the first page, the prices are for F-103, non-nippled. I assumed that everyone on Skylines Australia would be getting one for their Skyline.
If you are getting one for a car other than a Skyline, please check the part number and price for that vehicle and let Oxford know. If it is originally $49, then you will get the same discount. If it's more, or you need an adaptor (eg. Honda S2000), then the price will be different.
You should check your bank to make sure payments have arrived..hahaha I put in the wrong account number, lucky it came back to me :O
All fixed up and Paid with the correct account today :laugh:
Alright well I took a look under the front of my Stagea and lined up what it there and at what levels and here is my interpretation:
So here are the explanations:
RED - This is the bottom most part of the lip on my front bar
YELLOW - This is the bottom most part of the actual front bar
GREEN - Front part of the front subframe
BLACK - I dont know what the name for it is, but it s huge thick peice of metal that runs just behind the sump
PURPLE - The Sump itself
BLUE - The sump plug
So yes if anything hits the sump plug it's going to hit that big black thingy too, but I noticed that there is a small hole in the subfram bit that runs in front of the sump plug, so I might just bolt a peice of 5mm thick steel there that protrudes down a bit o add that little bit of extra protection.
Does it cost extra for the nipple version?
Yes, the nippled version is $4 extra. Unless your sump drain hole is behind a sump guard (and you couldn't be bothered taking the sump guard off every time you change the oil), you don't need the nippled one (to attach a hose to). Just open the valve and let the oil drop straight down into your oil pan.
Yeah I would rather attach a hose but that is just me :rolleyes: for ~10% extra on the price, just for the nipple........ meh I can do without.
How much are the units normally without postage?
Horses for courses. Just be aware that the nipple adds an extra 18mm to the valve's length.
Non-nippled with out postage is $49, nippled $54. Postage is normally $7
So at $41 delivered, that's not a bad deal.
Sorry, no defensiveness intended. I'm here to answer all your questions.
And you've done well - well done and cheers for the group buy (Ox and Fumoto)
the big black steel bit you are referring to ska is the main crossmember for the front section of the chassis.
in the pics i took under my car you can see the crossmember just behind the drain i have installed, so this should give you a clearer indication of where it will be situated once you install it
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
