  • Replies 107
Posted Images
how long will it take to receive delivery of the product after the purchase date of the 31st? as i have to change my oil pretty soon lol.. but im in for one as well for RB25 pending your answer :laugh:
how long will it take to receive delivery of the product after the purchase date of the 31st? as i have to change my oil pretty soon lol.. but im in as well pending your answer :angry:
You should get them a couple of days after Oxford transfers the money and it clears.
the buy is sposed to be ending tomorrow guys please advise if still interested!!so i can finalise the buy.
at this stage we have only 10 people that have paid up and a few that have pulled out, but there are a few remaining that have not let me know if they wanna go ahead.
so 10 ppl does that mean have to transfer $45 instead of the $41?... (since most ppl have transferd $41)
count me in for '90 RB26
will send payment once i get which price to pay lol
I paid last week, you really need to let people know if they're payment has been recieved mate. especially since the end date has come and gone...
I'd just like to know if the money has reached you or not...
hiya all
just to let ya know that the group buy will be finalised on monday and all the deposits from people will be paid to the distributor on tues or wed.
so hopefully they will be sent out to you guys by the weekend.
but if you would still like one i will be buying a few extras to have if ppl are still keen, only difference will be they will cost $41 plus postage(instead of $41 including postage)
cheers oxford.
hello all
just to let you all know i finalised the purchase of the valves today and they should all be delivered by weeks end hopefully as promised.
cheers oxford
Edited by oxford1327
...now that i do have the valve and can finally get around to changing the engine oil, what should i replace the oil with? (weight, brand etc)
hiya andy
i use MOTUL oils in both my bikes and my cars, they are good quality without being horrendesly expensive, 5ltrs of turbolight 4100 which is a 10/40 weight oil should set you back around $45-50 depending on where ya get it. when you do the oil change don't forget to put a light smear of oil (clean of course)around the gasket surface of the valve to assist in it sealing correctly.
as these oils have scrubbers added in them when you change it, it should come out black as this means it has cleaned the carbons and silts out of your system.
if the oil comes out cleanish so to speak it means it has not really been decarbonising anything inside the engine, which over time can lead to earlier than normal bearing damage or failure.
hope this helps.
cheers oxford
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
