Hey all just wondering if anyone knows where i can get some cheap shocks for the rear in Sydney. my rear shocks are stuffed.
I dont really want to go full performance as i dont really thrash the car round corners or anything like that so i'm happy with just some standard ones. If anyone can direct me to some places and some prices it would be appreciated..
thanks all.
https://www.sau.com.au/forums/topic/12788-shocks/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
