I have a set of brand new Eagle Forged H-Beam Con-Rods to suit Rb30
They come with ARP 2000 rod bolts and assembly lubricant
They are used by many people and are capable of 800hp+
*3d design offers redused weight without sacrificing strength.
*2 peice forginf for increased strength
*ARP 8740 cap screw bolt (190,00psi) and assembly lubricant
*Silicone bronze bushed for floating pins
*Certified 4340 steel, vacume degassed to remove impurities.
*Each forging is X-Rayed, sonic tested, magnafluxed to insure quality.
*Shotpeened & stress relieved.
*Comes with conrod bearings, assembly instructions and assembly lubricant
Price $750
Located in Kellyville Sydney will post
phone Jake 0404080448 or PM
  • 2 months later...
will these fit RB26??
cms
I'm very sure that all RB25\RB26\RB30 rods are the same length and will fit each other fine. (you would never use RB25 rods again though, they are shit)
The crank is what makes the larger capacity.
Edited by The Mafia
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
