Judd, I know of the restriction that is maf,
The link is not going to stay, as such I may need to quickly remove it and go back to factory. I still want to get either a wolf 3D or a LTX 12 Microtech. Im in the process of making up an adapter to replace the Maf to bolt to the air box. Also thinking of making the piping bigger from the air box to the Turbo inlet.
Regards Damqik
How is a maf restrictive? An 80mm hole will flow a lot of air, or if you need 90mm - you could use an infinity AFM with a power fc.
Only good for idle, what about af metering on cruise? Doesnt MAF use closed loop = better for part throttle and cruising? Also, if you upgrade a turbo, MAF would be better, ie you dont need to immediately retune before you drive as MAP measures only pressure not volume of air flow (different turbos flow diffent volumes at the same pressure).
I am not saying MAP is bad, just pros and cons for both. I believe I have seen some pretty huge hp cars out of Japan running power fc.
From what people have been saying, the new wolf 3d v4 sounds pretty tasty - in the past they have been an entry type ecu, but the new one sounds sweet.
Autronic is made by one of the developers for Motec (he split from the company), it is a bit dearer than a wolf - but would be very hard to fault as an ecu
The power fc provides full stock ecu functionality, very easy to tune and are also a tried and tested (and very effective) ecu.
At the end of the day - if you are not intending to tune the car yourself, speak to your workshop and ask what they recommend, and what they can deliver with that ecu.
another 2cents worth.
Im with Steve, AFMs on CA18/SR20 etc are very restrictive as they have a small bore, i think approx 48mm. Crappy and should be thrown inthe bin!!!
RB AFMs are 80mm in diam, thats over 3", and who here is running 3" pipe to their turbo??? You need to be trying pretty hard to get choked flow thru an 80mm opening.
Choked flow is when no more air can physically pass thru an opening/orifice, ie thats why restrictors are used in some categories of motorsport, to limit airflow and hp. I think rally cars run thru 32mm restrictors and they still make good power, though their is an increased expense in engineering diffusers before the restrictors.
AFM cars are more flexible when bumping up boost etc, when MAP sensed cars can need re-tuning to suit. Also cams can sometimes upset MAP sensed cars due to unstable inlet pressures resulting from lift and duration of cams... read 1000-1200rpm idle.
Economy/emmisions is increased with AFM, thats why manufacturers use it in order to comply with ever tighter legislation.
But please stop saying that RB AFMs are restricitve and should be resigned to being pencil holders, they are an example of how AFM should be made.
Remember not all AFM are created equal.The Nissan RB unit is a Hot Wire Airflow Meter (Nissan RB) that is far superior to crappy Vane Airflow Meters , or troublesome Ultrasonic types.
Whichever way you go OE AFM or MAP, set up and tuned correctly you will reap the rewards.
I hear what youu guy's are saying about maf and I think Nissan Japan got things right first time for a street car, but I disagree about the 80mm opening as the hot wire probe would reduce the amount of air that could travel past, and then theres the screens (which I lost the week after buying my car 2 1/2 years ago) it would be more like 60mm opening at the end of the day. I'm currently running map, I can run in closed loop (link ecu) so no issue there with regards to the cam issue I can run mixed mode TPS/Map so also no prob's
I guess its different strokes for different foke's like rb20, rb25, rb26 & rb30 and all the others mixed between. so it is with MAP & MAF one guy will say one thing another will say another thing.
We all like 9 sec skylines dose it matter how they do it?
Motec are an Aussie ECU, and are used internationally in many forms of motorsport. 2nd hand they still go for upwards of 3k with all the bits, they are a well engineered ECU.
The hot wire probe is what about 4mm in diam max?? That does reduce surface area, but as a percentage????
As i understand it the reason big HP cars run MAP sensors is beacuse a MAP sensor will run anything from a Charade to 1000hp drag car, as long as its not running more boost then the sensor can withstand.
Now problem with AFM is that they need to be sized for application, i think only the yanks make aftermarket AFMs for their chevs etc. An MX-5 Vane AFM isnt going to run your T88 RB26.
Not too many factory cars making 600hp for us to go and steal the AFM off. Then theres the prob with ECUs recognising the voltage signals, ok almost universaly 0-5V but what voltage equates to what airflow.
So what happens, aftermarket ECUs recognising that AFM are application dependent (ie not universal), base their computers on running MAP sensors, meaning they can be used for any hp application.
You and I see aftermarket performance ECUs using Map sensors and think they are the duck guts Max.
Not knee capping MAP sensed cars or their owners, im standing up for the poor old AFM that is forever being bashed. So yes MAP are used on big hp cars but not for the reason many think.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
