have nissan rb20 motor,all the parts on it are for sale (not selling whole only in parts)
rb20det head $250
rb20det stock plenum $200 (the whole lot)
rb20det stock turbo and dump pipe $150 (had lettle play in it)
rb20det stock alt $100
rb20det Cooler with Piping (Only To Engine Bay) $80
rb20det throttle body $50
rb20det Exhaust mainfold $80
rb20det airconditioning pump $80
all other parts are for sale of the motor just ask
silvia two front lights one is broken $80
2 front seats drivers has rip no rails $100
pm or ring zack on 04025582378
iam in nelson bay 45 mins north from newcastle
or might swap for after market stuff for rb20 motor
some stuff i need ,afm,turbo timer,taco's,boost controller,cooler,and let me know if u have any thing else
I will listen to offers as long as they are reasonable.
all parts are Negotiable!!!!!!!!
Edited by 2bevil
https://www.sau.com.au/forums/topic/128113-rb20-motor-partssome-silvia-parts/
'Jago'
where are u located = nelson bay 45mins north from newcastle
complete RB20 bottom end = the block has a crack in it so i dont think it would be any good but can sell u all the internal parts if u like
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
