I've done a search and found a few answers, but not all. Apologies if these questions have already been answered but keep in mind that there were a lot more to begin with that I would have also asked if I didn't search :P
Ok, it seems the general consensus is that once you hit around 220rwkw, you'll need to upgrade your fuel pump, and possibly the regulator. I am looking at getting a Bosch 044 for this reason.
The most important question I need to ask is - What is the part number? The reason I ask is because I have a friend who *may* be able to get me wholesale prices, because his company deals with Bosch. But since it's mostly NOT for car stuff (mostly power tools and other electrics), he'll need a part number rather than just ordering a "Bosch 044 fuel pump".
My next question is would I also need to upgrade my regulator at the same time? If so, what should I be looking at getting, and roughly how much should I be spending? I don't care about brand names, as long as it does the job I'll be happy with a cheapie (but preferably new) item.
Oh, and lastly - are these things relatively easy to fit yourself? Do they bolt straight up or do they need an adaptor of sorts? Do I need to pull the fuel tank out to fit everything?
https://www.sau.com.au/forums/topic/12826-fuel-pump-and-regulator/
Despite I have one, I have no idea what the part# is.
You shouldn't necessarily need to replace / upgrade the pressure reg.
email the boys at Zoom ([email protected]) and ask them which issue had the article about installing the upgraded pump - but its not a simple pull-one-out-put-one-in upgrade though.
Good Q's Jimmy coz im up to the same type of area with my mods.
203rwkw and im thinking that a Rising Rate Fuel Regulator ~$190 should help fix up my leaning out problem at top end on 12psi. Even if it doesn't it'll be needed anyway sometime throughout this year.
The Rising Rate Fuel Regulator needs to be tuned I believe ?
Lemme know if you get any prices Jimmy I might be in for a group buy :P
Ben, where are you getting the rising rate regulator from? Where does it actually go? At the tank or the fuel rail or somewhere in between?
Blind_Elk, I've emailed them and am waiting for a response. Off-hand do you know roughly what's involved? Like, do I have to cut a section out of the tank, make an adapter, drill new mounting holes, etc? How much would a performance shop charge to do all this for me? I'm pretty handy with a spanner, but working around fuel makes me nervous :P
Thanks for that info Browny, but after reading the thread I just have more questions :P
The 044 seems to be too big for my application, if the cheaper 984 can flow up to 600hp. Even 600hp is way beyond the scope of anything I want to do with the car in the near future, so should I be looking at getting the 984 instead and save myself $100?
Are all these pumps pretty much the same size and shape, or do some require more or less work to fit and get working properly?
Edit: 'nother question - Am I getting an internal or external pump here?
I did a search on google i think for aussie websites and they seem to be around the $195-$215 price for a brand new unit. I have absolutely no idea where they go or anything like that
:bahaha:
I just got a response from the guys at Zoom, they told me the fuel pump article is in issue 36, and that it's no longer available :P Can someone that has that issue please scan the article for all us fuel pump upgraders? :P
I can only do it in 'hard-copy' ie fax the pages to you. Do you have a fax# (pm me if you do). (And it won't be until tomorrow.)
Hi guys, fuel pump info as we know it.
GTST pump is 135 litres per hour and supports 300 bhp at standard pressure
GTR pump is 190 litres per hour and supports 420 bhp at standard pressure
Bosch 910 pump is 200 litres per hour and supports 450 bhp at 73.5 PSI 0 580 254 910
Bosch 975 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI 0 580 254 975
Bosch 984 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI 0 580 254 984
Bosch 044 pump is 330 litres per hour and supports 730 bhp at 73.5 PSI 0 580 254 044
Bosch 040 pump is 235 litres per hour and supports 520 bhp at 73.5 PSI 0 580 254 040
We use one GTR pump mounted in tank up to 400 bhp and for engine over 600 bhp we use twin GTR pumps with a surge tank and a GTST lift pump in tank.
Hope that helps
Question regarding the wiring up of these pumps. As I understand it at present, the factory pump doesn't pump out at full capacity all the time, it waits until you open the throttle up before giving it a full earth. There's another thread here that talks about giving the factory pump a constant earth all the time to help with stalling problems at idle.
Should the bigger Bosch pumps be hooked up in the same way or should we hardwire them to a constant earth? I'm mostly concerned with burning the pump out too early by running it constantly at full capacity. But if that's what they were designed to do (unlike the factory pump it seems) then that's what I'll do ;)
Edit: Oh yeah, thanks Sydneykid! I didn't even notice you had the part numbers in there at first, it kind of blended in at the end :D
Btw, since the 984 is good for up to 500hp, I think I'll go with that because my turbo only flows up to 450hp anyway. Unless the bigger 044 allows the stock injectors to flow a little better? If so I'll spend the extra $100 now so I can delay or put off indefinitely my injector upgrade.
Sydneykid, help!
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
