Hey all,
Have a few bits I need to offload as I need to channel the funds elsewhere right now, some prices are slightly negotiable, low ballers need not apply. All parts are in Melbourne, PM me or phone me (Chris - 0412 776 276) only if you're serious please. Details are as follows;
For sale: HKS 2535 turbo (56T), T3 flange suit RB20/25
Item Condition: Done 8000km from new and it shows, absolutely no shaft play.
Price and price conditions: $1650 DEPOSIT TAKEN
Extra Info: Comes with everything in pic (elbow, actuator etc) - note the 2535 are reputedly similar in responsivness to standard turbo on RB25, but with capacity to make up to 250kW with support mods - do a search here and see for yourself.
Note, my prefered option is to swap for R34 turbo, lines & elbow + $1200. If you have a good 34 turbo and wanna upgrade, please PM me. I've had a couple offers of this nature but I'm after a low km turbo that's ready to go...
Pictures: See at bottom
Contact Details: PM
Delivery & Conditions of Delivery: Pickup preferred, will courier interstate (direct deposit)
For sale: R32 GTS-t alloys, 16x6.5 (I think?)
Item Condition: Like new!
Price and price conditions: $350 SOLD
Extra Info: I had these powdercoated Dulux charcoal grey mettalic about 6 months ago and as such, they're in excellent condition. Rear tyres are worn, barely roadworthy, front tyres at least 75% - there's only a pic of one but all 4 look the same...(Duh)
Contact Details: PM, phone
Delivery & Conditions of Delivery: Pickup ONLY
For sale: R32 GTS-t M-Spec front bumper
Item Condition: Excellent
Price and price conditions: $290 (+freight) SOLD
Extra Info: Bought this from a forum member not long ago but now going a Vertex kit so no longer needed. Its in great condition, just rub it back and paint. Has plastic grills as well.
For sale: R32 factory mirrors (they're off 4 door but...?)
Item Condition: Good
Price and price conditions: $100. (+freight) SOLD
Extra Info: They still have original paint on them but are in great condition with no scratches, cracks and all glass intact and fine. Come with plug, just need to rub back, paint and fit em on. I bought them for my car but got an aero pair now...
For sale: R32 GTR injectors x 6
Item Condition: Great
Price and price conditions: $290 firm. (+freight) SOLD
Extra Info: Bought these which were apparently cleaned and flowed before I got them & I have the business card of the place that did it. Have no use for them now...so gotta go...
For sale: Q45 afm with plug
Price and price conditions: $180 (+freight) SOLD
Extra Info: Only done few thousand kms as seen in pics, in excellent condition, no use to on my RB20...comes with air filter attachment as well.
That's about it for the moment...if you have any further quesies, please let me know! :cheers:
Cheers,
Chris
Edited by 4doorHCR32
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
