  • Replies 41
Posted Images
  • 2 months later...
swap .... saw this car on boost n it lead me here ... check me out ....
http://www.boostcruising.com/forums/index....howtopic=261388
hey guyz i no this car pretty well and everything on this car has been done properly no dodgy work at all very well looked after car never thrashed and always kept A1 , goes good as well , GL with sale free bump
  • 3 weeks later...
