Thanks Bundybear, however the number doesn't look correct? Looks like yours is 0000210, should be 0002019
Thanks again :ph34r:
Simon
Sorry there Simon I seem to have plain old farked up
this one should be betta (fingerz X'd)
Hi, could you please check hcr32034806?
thanks!
Hope I got that one right 2 hehe
Cheers
:rant: That's cool, thanks for looking it up!! :D
I'll now go and find out what it all means :ermm:
Colour code KH2 :Gunmetal Grey Metallic
MT :Manual Trans
RB26DTT : RB26DETT <=Weird NISSAN thing
HickAss, 4WD
rest is preety easy
no interior colour code ?? does happen sometimes with FAST..
cherrs
MT :Manual Trans
HickAss, 4WD
rest is preety easy
cherrs
Thanks, that's great, i was actually interested in what the letters following the model number related to- the RXFSLMZG?
not sure bout 32z ( i got a 33, bitch 2 decode) but i'm reasonably sure theres 2 'decode model' thread on SAU somewhere that should let you decode the letters ( they represent different optional extraz )
a quick search should find them
cheers
cheers
Many thanks :P
and so is BCNR33041615 levelride's
bc210's BNR32003202 (even with BCNR)
in fact only yours work... here it is.. (so you're safe, phew)
I know mine's not a re-birth... If you want, I can post up a pic of the little blue plate on the firewall... Please try 1 more time through FAST... Cheers
seems my version can't lookup anything in the R32/R33 range.
so i'm sure it's problem at my end not any of your car are dodgy.
although look like I should be able to do it as all R32 R33 R34 range are on my FAST dvd.
including V35, V36 and R35
I got .. with FAST V3.50
:BC210
:levelride
Sorry dude no go with mine either
What is your model no , the 14 char one, I can do a look up on this instead, may get results
:DemsA31
cheers n beers
BBQ TUE
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
