i know someone who might be selling a high flowed rb25 turbo which is rated at 500hp and can hold 30 psi, it has a 500hp cosworth steel wheel on it apprently its good im not sure, dont know much at all about turbos however its for 1700 bucks witha 50mm wastegate, is there amajor differnce between highflowed turbos and brand names turbos such as garrets,HKS etc thanks for the advice in advance
Sam
https://www.sau.com.au/forums/topic/128782-thinking-of-upgrading-my-turbo/
There potentially can be a lot of difference
HKS/Garrett etc. Have put a great deal of money and development.
Places like GCG also put time and development into thier hi-flow/hybrid turbos etc.
Some places however do not. They simple slap some wheels in either end with a housing and thats about it.
They dont perform nearly aswell as thier more expensive/reasearched/developed brothers and as such you'll never have as good performance.
How much performance? Thats up for debate on a case-by-case basis.
By the sound of the turbo you speak of, its been modified and have the internal wastegate removed, hence the need for an external gate.
Thats probably issue #1, you'll need a spacer plate, modified stock manifold, or a new manifold to be able to accomodate the EXT wategate, which for a street car/mild applications really is going too far, and its pointless added cost.
Problem #2... kinda comes back on yourself. You need to find out the exact wheel trims/housings etc etc of the turbo for the resident experts to be able to give some indiction of how it will perform
At face value, if someone is saying to you "its 500hp, good for 30psi" then its gonna be just some bucket of shit turbo thats gonna be either laggy, unresponsive or surge like crazy.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
