What kind of funky arsed drugs have you smoked?
45 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Well here is a quick maths lesson....
Emo + idiocy + Lazyness = Humour
This is shown in this example, titled "Why not to leave your Emo son alone."
Here is our subject:
First thing your emo son will do is make a coffee.
Unfortunatly they will almost automatically start writing really bad poetry on napkins about drinking bleach when the autofroth outlet will spray out boiling milk all over their napkin, causing them to lash out and break the coffee machine by trying to recite the last poem that was destroyed on the napkin, it's all about the dangers of dating your sister.
After that, they will go make a nice cup of orange juice, but why peel when you have a juicer.
Unfortunatly most juicers were never designed to be used by emo's and so the emo will most surely break it somehow, meaning that the safety switch will be so overwhelmed that it will shut the whole thing down, rendering it useless.
So to clean up the Emo will throw the coffe machine ad the juicer, whole mind you, into the dishwasher.
After setting it to scrub clean, the emo will then wonder why he never thought of sticking his head into it and turning it on, oh hang on a sec that is right, that only works for gas stoves, too bad the emo is too stupid to figure this out and might try this at this stage. But wait, when he does go to try, it is not working.
So knowing absolutly nothing about dishwashers and all the completities involved with troubleshooting and repair, the emo will try to apply his own brand of "troubleshooting" and use the knife he usually uses to cut himself, as a screw driver and sets forth to "fix" the broken down thingermagigger.
After totally destroying the dishwasher, he will look around at the complete mess he has made.
And then retire to his clean room, clean for emo standards.
But enroute pass two butt ugly african things and wonder which one he will make love to tonight.
And as always he will never take the rubbish out to the bin, not unless it had some bleach he could drink in it.
But who really gives a shit, this little emo boy is a wallstreet power charger and they call him, "The Seller" in the real estate business, he'll just call up "Cleaner Hoes" and get them to clean it up for him!
https://www.sau.com.au/forums/topic/129057-urgent-parental-public-warning/
  • Replies 69
Didnt cost you that much cnut, you just used the hair straightener that me and jade bought you for christmas :P
Nah I went to that new “bounce” salon in Noosaville the other week. I swear they saw me coming with charging me that much!
Especially considering all they did was make you look even more stupid! You got jibbed hard man. $20 most ever for a hair cut. You tell them that. That haircut tho, $1.
i usually pay around $35 for a haircut.... and its usually nothing more than shaving the sides/back of my head, and trimming the top...
because
a) the chicks that they employ there are f**kin hot
b) they give good head (massages)
c) they are hot
d) they do a half-decent job of cutting my hair...
though, all the super hot ones seem to have left now, so i might start searching for a new hairdresser.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
