I know this topic has been heavily discussed before, but I couldnt help noticing that a great number of you have sydney kid suspension on your wish list of future mods....can someone please tell me what make/brand these are? adjustables or lowered springs on aftermarket shocks?
I dont know what suspension components are installed on my rs4, came lowered from japan...but currently it rides like a brick....not really ideal if you're crusing on a full stomach.
https://www.sau.com.au/forums/topic/129328-suspension-upgrade/
http://www.skylinesaustralia.com/forums/in...showtopic=53079
simple, Sydneykids specs involving Bilstein shocks and Whiteline components (springs, bushes, swaybars etc). I went without the springs (using standard) and find it a most suitable ride.
edit: to lower it or raise the suspension, SK had "notches" scrapped into the shocks, and you can adjust the height simply using circlips. pretty much they are lowered springs on aftermarket shocks
Edited by Tangles
Sorry to steal the thread but it seemed like a logical place to ask...
What colour should the bilstein rear shocks be?
The ones in pictures I've seen are yellow whereas I've had mine replaced under dealer warranty some time ago and was told they were bilsteins, yet they are black. They are definitely new though and provide a very comfortable ride.
Genuine Bilstein shocks have "BILSTEIN" machine into the shock body along with the part numbers. Thye are usually down near the lower shock mount.
:devil: cheers :down:
wouldn't cutting threads into the shock body compromise the strenght of the overall assembly?
Nope, Bilstein Skyline shocks come with circlip grooves standard, the Group Buy simply adds a few more. The shock body is designed for that purpose.
:wave: cheers :D
Edited by Sydneykid
Well seeing as though we are asking questions in here, and I dont want to muddy up the ongoing thread....
Can someone explain to me this approx 10mm rake effect... From what I can deduce if you wanted a 10mm rake effect for the nose down... wouldnt you then want the distance from the centre of the wheels to the wheel arch on the front to be 10mm less then the distance on the back wheels? I find it confusing because everywhere I am reading of this nose down rake effect and the measurement are always higher on the front and not the back...
Please help a poor confused man :wave:
Can someone explain to me this approx 10mm rake effect... From what I can deduce if you wanted a 10mm rake effect for the nose down... wouldnt you then want the distance from the centre of the wheels to the wheel arch on the front to be 10mm less then the distance on the back wheels? I find it confusing because everywhere I am reading of this nose down rake effect and the measurement are always higher on the front and not the bad...
The front and rear guards openings are not "cut" to the same height. The rear guard opening is in fact ~15 mm lower than the front guard opening.
Hence, rake is best measured at the sill (just behind the front wheels and just in front of the rear wheels), that's where the 10 mm nose down comes from.
:D cheers :(
Thanks sydneykid. I'll email you when its time to change the shockies on my car. right now i'm saving up for a FMIC and SAFC (will have to do this on the sly coz my wife has a tight grip on finances at the moment)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
