Just got off the phone to Andy & he has tuned 2 r33 this week with basically they same mods & they were in 180rwkw bracket! The only difference is that the were running 95ron! so the 98ron stuff aint looking to good!
The first tank of 98 I ran in the GTR I had to pull a couple of degrees out of it because it was pinging a bit so.... could be.
I'm assuming that Kutzie is tuning the thing to the point just before detonation. And that the detonation is the limmiting factor for your combination.
It's obviously not the dyno, I doubt it would be Kutzie's operation. That leaves ur car...
I could be a lot of different things.
It could quite possibly have a higher static comp ratio. Or silly things like a dodgy injector, a wrong set of spark plugs (often the tips heat up to a point where they induce detonation), a broken or damaged spark plug.
If it's been re-built, dose it have a DET head? Has somone f**ked around with the combustion chambers or ports?? You could be getting hot spots at the point of combustion.
Do you have an unknown blockage in ur exhaust system (stuffed cat or muffler can cause so much back preassure in the housing, heats up the exhaust valvesw and induces detonation), intake or charge pipes.
Do you still have a stock crank case breather set up? It's not uncommon for a rebuit engine to breath a little heavier (depending on the way the builder set gaps and clearances) and if you have those lines going back into ur intake that can induce detonation. Maybe get urself an oil air seperator or catch can.
It could be lots of things......
OR
You just got a dodgy tank of fuel. I can vouch for the fresh tank at BP in Kingston atm.
Oh by the way. If you do take it to another dyno and the operator dosn't have a super keen ear or a Knock Box (Head Phones and amplifier to listen for pre-detonation)... with ur car, wich is super prone to detonation... You might be building urself another motor.
Plus, if u do get a higher reading on another dyno, it still dosn't mean you have more power.
If I had ur problem, I'd replace my plugs, use a very good oil and filter, drop my exhaust and check the cat, take my pipe work apart and have a look, run another tank of 98 through it then take it back, strap it down and see what happens... you'll know quite quickly if it'll make more power.
Sory about the long post.
As far as i know about the rebuild dav griffith put in the following:
forged piston set 20tho
gtr rods
arp conrod bolt set
race series main bearing set
bigend bearing set
nissan gaskets
nissan cam belt
basically the rebuild was ment to be achieve basically standard spec with just them parts setup to achieve that!
yes it still has the DET head on it!
yes kutzie did tune it to the point just before detonation, but backed off abit!
exhaust is fine less than 3months old!
im not gonna bother taking it to anyone else cause kutzie know's his shit!
he said for starter run some 95ron through is and get it back on the dyno & that will bascailly tell me weather its the fuel or my motor!
Cheers
Al
This should be an interesting test then, as my new RB25 is being tuned in Melbourne at the moment on 98ron. To see if there is any difference in the 98ron fuel that comes over base straight, And also the power difference! Dyno to Dyno as there is about 15 cars in Hobart that have also been tuned by this dyno that is in Melbourne as well. (Sam Cornell’s)
Once I have run a couple of 98ron tanks through it in Hobart, I will take my car to Pro and see kutzie and check it on his dyno
I do think it could be your motor by the sounds of things and as XRATED has said go through every thing and check it.
I know of at least 30+ people running BP 98ron in Hobart and none of them have hade any problems at all.
Yer i think the fuel is good! & the Problem with my power output is that my turbo is about to shit its self! Took a temp reading off one of the pipe's that comes of the turbo & it was 95' degree's @ full noise. plus it wont hold anymore than .7bar it keeps dropping back & that with an AVCR. So im goin to do Turbo & 555cc Nismo Injectors. And then let Andy have another go!
What turbo's are people running? any suggestions? I was thinking of this one:
Spec as follows: GT30R
Bolt on GTS-T Turbine Housing 0.70a/r Internal Gate
Turbine Wheel = 84trim
GT Ball Beareing Garrett Core
Comp Wheel = 56trim, 57mm Inducer
Comp Housing = 0.60a/r Approx HP = 450hp Flywheel
Alan
Edited by al_r33
Sounds like a fairly pointless comparison to me; no two dynos and no two dyno runs are exactly the same, IMHO the only before and after testing worth even using as an advisory figure is done on one dyno and one only.
Anyway, 138rwkw is very average. My 17 year old redtop RB20, with a high rpm misfire and 10psi boost, stock except for a 3" cat back squeaked out 116rwkw. For an RB25DET to make 138rwkw with a rebuild and your mods something has to be seriously not right. Even a REALLY low reading dyno wouldn't account for that, IMO.
No sh!t no two dynos are the same every one nows that,
Mainly just to check to make shore the fuel is ok!
Alan....
Ive just read all about your problem...WOW
With what you seem to have done to your engine and all the right mods by now you should be putting out towards the 200 mark
Dont bite my head of for asking but is your R33 a Automatic...
Alan....
yeah Al's car is manual and im pretty sure he has narrowed it down to a dicky turbo.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
