Pretty interesting.. they're releasing F.E.A.R Combat, the multiplayer component totally free in a week or so for free download for PC.
Guess they're trying to make it a cult following, along the lines of Counter Strike, etc.
Wouldn't mind getting back into it, after I sold the game to some @#$@#$ on ebay who never paid me for it :D
http://www.slicedgaming.com/news9421.html
https://www.sau.com.au/forums/topic/129453-fear-multiplayer-goes-free/
stoopid thing.. counter is on big fat zero and nothing.. it looks like it's based on your system clock, not a proper server time.
embarassing for the publishers if you ask me, to allow it to happen.
Huh?
I downloaded it over the weekend but have yet to install it.....
I'll speak to you on MSN 2night if your on...
Is it any good though?
just make a 5 zip postcode bl4ck32.. jeez :D
it does require some heavy resources, but runs ok on my older spec pc..
The levels are pretty tight, and it's easy to get into.. only played it for a couple of sessions though.. got too much other stuff on at the moment :D
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
