Good call/find Howie !!
I've had the same stains on my back window since the last Skid Pan day ( they use bore water at the Skid Pans which stains / eats into your car if left to dry ).
Couldn't get #4 Heavy Cut ( Meguires told me they don't sell it any more ) so I got #2 Medium Cut and it worked a treat :D Needed a bit more elbow grease but it cleaned up great. I then used windex/metho to clean the glass and then hit it with a coat of Rainex. Forgot glass could look that good !!
Cheers :O
Glad to hear mate! :D
Heavy Cut Cleaner was replaced by Diamond Polish series. I ended up getting the Diamond Polish. Basically anything with a strong cut and a diminishing abrasive will work. I'll grab some pics sometime this weekend after i've cleaned up all my windows.
End results with Diamond Cut Polish. Took two attempts to get rid of it completely.
Comparison ... left side one polish, right side second polish...
Fully removed here.
I didn't realise how rough the surface of your windows can get until i went over it with the diamond cut... when you first apply it, you see exactly where oxidation has taken place, as there are distinct outlines, you end up taking out rough surfaces which you didn't know where there in the first place. After this i'm going to do all the windows including the front windscreen. Did i mention it works great on your headlights and foggies too?
Edited by Howie
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
