Gb: Brand New Z32 Afm's - $330.00 Each
Hi guys, while looking around for some new Air Flow Meters for my GTR, I have found a great deal for brand new Z32 AFM's which sees these new AFM's priced only a touch higher than what you would expect to pay for a used item.
Just Jap in Sydney has kindly offered to supply the AFM's for this group buy for $330.00 Each (Inc GST)
Tomei Z32 adapter plugs will be available as an optional extra for $49.00 each.
Important Information:
* These are genuine Bosch Z32 Air Flow Meters
* Each AFM includes a 12 month warranty
* We require 10 or more buyers for this group buy to proceed
* Express delivery is available for $10.00 Australia-wide
* The closing date for this offer is firm
Once we have 10 people confirmed on the list, the order will be placed and you will then be asked to make your payment.
Pickup will be available from Just Jap in Kirrawee, Sydney (South), when the group buy concludes, otherwise express delivery is available
Note: I have already confirmed stock availability with Just Jap
Group Buy Start Date: 15/8/2006
Group Buy End Date: 15/9/2006
Making your payment
Payments will be accepted only via direct deposit - Instructions for payment will be supplied at a later stage.
What are you waiting for? Register your interest NOW :)
BUYERS CONFIRMED:
Blitz 2 x AFM + 2 x Tomei AFM Plug PAID & CONFIRMED & POSTED
d00dz 1 x AFM PAID & CONFIRMED & POSTED
Danoz 2 x AFM + 2 x Tomei AFM Plug PAID
rbsilvia 1 x AFM + 1 x Tomei AFM Plug
FLYSLY 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
Crack 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
AcoustiK 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
_8OO5TED_ 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
pulp 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
2face 1 x AFM + 1 x Tomei AFM Plug
al_r33 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
steves180 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
babia 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
writeoff 2 x AFM
jetdat 1 x AFM & 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
darkl0n 1 x AFM & 1 x Tomei AFM Plug PAID
R334Door 1 x AFM PAID
https://www.sau.com.au/forums/topic/130308-gb-brand-new-z32-afms-33000-each/
  • Replies 117
Registering interest.
Can I pickup?
Now to find plugs for this hmmm
Vic, no need to find plugs, they can also supply the Tomei Z32 plug adapters, will append the first post shortly with details.
Also as above, pickup will be available at the conclusion of this group buy
How do i know if i need the adapter?
If you are fitting this to a Silvia, GTS-T, GTR etc, you will need the adapter plug as your factory AFM plug will not fit onto the Z32 AFM.
Ok how soon can i pay for this and have it delivered?
Looking to get one ASAP
They are ready to go, however we need 10 people confirmed to secure this price of $330.
Would you like me to mark you down as confirmed?
Yes im definately in, works out cheaper than nengun which is awesome
Thanks mate, I have added you to the list.
Will you be wanting the AFM adapter as well?
Yeh sorry mate.. im eager thats all
Its a bargain and an AFM is something that a lot of people would be due to buy so we should fill up the 10 easily and fairly quickly i'd imagine...
Not very often things go cheaper here than from greenline or nengun.
Hopefully it will arrive faster too I dont want to have to wait 2 weeks...
Thanks for organising this - great group buy
Happy to help mate.
Once we reach the minimum order (10), and your payment is processed they will be ready for pickup and dispatch straight away - A quantity of them is already set aside for this group buy :)
I will advise more details soon.
Nick
Keen on one with adapter, but a couple of q's
Would I need a tuner to hook up the plug, or can it be just adapted to the existing plug? Also, do I need to retune my ECU?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
