Gb: Brand New Z32 Afm's - $330.00 Each
  • Replies 117
Blitz, this may seem like a sil question, but is there any difference between the genuine Bosch item and a Nismo one?
The Bosch/Nissan Z32 AFM's are 80mm,where the Nismo/Tomei units are smaller in physical size, but still have increased voltage capabilities over the standard AFM - They are also significantly more expensive and tuners I have spoken to seem to prefer the standard type 80mm Z32 over the Nismo/Tomei type units.
Hope this helps
Payment made and email sent to Darron
Alan
Hi Alan, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581246)
Cheers,
Nick
Received the AFM yesterday, damn quick delivery :ninja: Thanks mate.
Anyways anybody know the wire colour codes for a R34GTT e.g which ones signal, batt etc, gonna splice and hook up myself...
Your very welcome mate :ninja:
Payment made and email sent to Darron :ninja:
Gday Matt, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581247)
Cheers,
Nick
CAn you hook these units up to a stock RB20DET and see a difference or will it be just a waste of time until i get my Power FC?
Thanks guys
You will need to wait until you have a Power FC :D
Woohoo! Received mine today! thanks mate! :D
Also does it matter if on one side of the mesh it's slightly dented? doesn't look too bad might be able to gently move it back in place.
Cheers again!
Received the AFM yesterday, damn quick delivery :D Thanks mate.
Hey AcoustiK, try this thread, might help you a bit! :yes:
http://www.skylinesaustralia.com/forums/in...howtopic=116520
Woohoo! Received mine today! thanks mate! ;)
Cheers again!
Hi Dave, glad to hear it arrived safely - The dent in the mesh wont be a problem, in some cases people remove the mesh all together.
Hey Blitz,
Just transfered the funds, and emailed Darron too.
Thanks
Hi Nikki, your payment has been confirmed and is on its way to you via express post (Ref: # SN0581250)
Cheers,
Nick
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
